41 - 50 of 50 Posts
14' VW Touareg Execline R-line TDI
I would say it has to be coded just like coding the amber tail light signals. But anyone have any luck finding the coding for this?
I played in vagcom and actually found a way to disable them! The problem was it illuminated a light on my dash and every after I got the fogs while turning re-activated, I had to do a systems scan of the lighting system for it to go away. It was a lot of work too and I panicked a bit lol.
What did you have to change?
Honestly I don't remember... I was digging deep into the menu system and when I got those 1 or 2 permanent illumination error lights I panicked and wanted them gone lol. They might have even gone away if I did a re-calibration and NOT set them back to stock, I dunno.
In the green screen or vcds?
VCDS
I think it was probably under the lighting module that I played w/ it
2011 Touareg VR6 FSI
It's been a while since I visited this thread trying to find out how to disable the fog lights while cornering. It turns out that Njord was right in post #12. As a plus this also disables the front fog lights from coming on when in reverse.
You tried it and it worked??
WOW this is great. Gonna do it asap! Thank you!
41 - 50 of 50 Posts
