1 - 20 of 21 Posts
As an introductory special, we are offering our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: touareg
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid till September 7th, and is only for the lower 48 states.
I followed your instructions and tried to purchase with your discount but there is no place to enter a code for the discount when checking out using paypal. How do you enter the code touareg to receive the $99.00 price?
Enter the code BEFORE you hit check out. You have to update your cart to get the discount...
What you will want to do is press the “Buy Now” button on the website. This will take you to the “Purchase Online” section. There is a pull-down menu with two options. You want to select the wrench with case option ($150 retail). Then press “Add to Cart”. This will then take you to a window where there is a space to enter your zip code as well as a coupon code. This is where you want to enter “touareg”. Then press “Update Cart” and the $99 price will appear. You can then check-out using Paypal or Google-Checkout. You can also use a credit card if you do not have a Paypal account, but you still need to press the Paypal button. Please let me know if this does not solve the problem for you.
BLMW
Dark Lord of the Sith
I bet my wife would disagree if I bought one for her.....:wave:
Just ordered mine as a Christmas present to myself. Thanks!
David
I bought one of these earlier this month......very nice wrench.....very user friendly......I took off my summer wheels and mounted up my winter wheels and used it to torque my lug bolts to 180 NM......;)
Well worth the money in my opinion !
My God,it's full of stars
Still waiting for Brownlinemetal to let me know what the shipping is as I'm looking at a Craftsman drill press that I could really use...
siberian
I'd just like to give a word of caution. It's a great feature to have a reversible torque wrench but it's really of limited use. You shouldn't use it to judge the torque setting of any bolt that's been on there for a while. For example, if you change your rotors and remove the calipers, since they've been there for over 40k miles, they've no doubt frozen in place with heat and cold. The reading you'll get (assuming it's under 150ft/lbs) is NOT to be used to determine what they were initially torqued at...
Just a word to the wise.
siberian
siberian said:
For the calipers for example, half inch is what you need.
siberian
Already have a half inch torque wrench, my 3/8" is dial type, which would necessitate the need for a replacement.
Can you not use a 1/2" to 3/8" adapter on this?
I would contact the seller and see whether a 3/8 to 1/2 inch adapter will affect the readings.
siberian
1 - 20 of 21 Posts
About this Discussion
7 Participants
brownlinemetal
Club Touareg Forum
Full Forum Listing
