Hi guys,
I have been losing coolant from my 2013 Treg TDI for the last 2 months. The car is running great but it's lost about two quarts just in the last 2 weeks. The common leak in the valley was repaired 12 months ago... the one discussed in this thread 2013 3.0 TDI - Probable EGR Valve coolant leak
There's no visible leak and no smell so I decided to have an oil sample checked. The testing confirmed coolant is getting in the oil. Can you anyone give me some advice on how to diagnose where it could be leaking? Oil cooler maybe? Head gasket? After reading through some threads here I see that there's a device available called a combustion leak tester. If that test is positive does that definitely mean its a head gasket?
The front flange had to be removed when the leak in the valley was repaired. There's an intricate gasket that seals it to the front of the block. I wonder if it could've let go...it was totally trouble free for 10 months/5000 miles after that repair though.
I just don't know enough right now to even know how to narrow it down to a certain part. I love my car though and it'll be a sad day if it's the end of the line. Thanks for any help!
