waste gate?
I didn't think the V10 turbos had a turbo waste gate. I thought the turbos used (variable) vane attitude to control the amount of turbo RPM (and therefore boost). I think there are vanes on the turbo housing that can adjust the amount of exhaust gas that hits the turbo vanes.
I imagine that you would get some spool-up with a power brake launch, but I would think that the ECU would "feather" the turbo vanes in response to engine load. Of course, I'd guess that there is some load on the engine with a power brake launch...even if you're not moving.
Only one way to find out...hook up the VAGCOM and measure the turbo/boost blocks during the power brake segment of the run.
[/img]
