1 - 4 of 4 Posts
Hotdog130
Discussion starter · #1 ·
Had to replace DEF Tank Heater Assembly due to a P205B Fault Code
Now that this has been replaced the vehicle won't start, I ran VCDS and don't see anything that should be stopping it from starting. Any suggestions would be appreciated, here is the report from VCDS for reference:
Saturday,28,May,2022,16:54:15:50148
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVGFK9BP5BD002711 License Plate:
Mileage: 231257km-143696mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 65 69
6C 6D 72
VIN: WVGFK9BP5BD002711 Mileage: 231257km-143696miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI FSA H21 0008
Revision: 56H21--- CVN: 66FD960038D3FF82755A2113
Coding: 292A4012233600050000
Shop #: WSC 04913 444 00000
ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
ROD: EV_ECM30TDI0117P0907401J_002.rod
VCID: 3635DA8408CB43FB253-8062
VINID: 9E65D66C94A01525000021C104CB03F616
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 3407
Serial number: CVN: CB5A7D50
Coding: 001368
Shop #: WSC 04000 004 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_VW52.rod
VCID: 3039EC9CEAAF6DCB7FF-8064
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 E HW: 7P0 907 379 A
Component: MK25A H33 0416
Revision: -------- Serial number: 428100010EC010
Coding: 5B7613C349242555DAFBC89492D3A4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 3FDBBFA027F182B3F65-806A
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H23 0208
Revision: 00002001
Coding: 09860000000000000000
VCID: 72BD269424A31FDBC9B-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0810000087876008
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000022325009
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 225439 km
Time Indication: 0
Date: 2022.03.14
Time: 07:24:31
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0612
Coding: B606200880
VCID: 79AF11B879556C83881-802C
1 Fault Found:
0325 - Control Module for Auxiliary Heater
B10C0 16 [008] - Voltage Too Low
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 31
Mileage: 231257 km
Date: 2022.05.28
Time: 16:44:25
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 D HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0083
Revision: 15012002 Serial number: 00000000665933
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 290F01F8C9F51C03B81-807C
Component: WWS 100930 31 0020
Serial number: 90243400101008000619
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10071163
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000000610100321
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R03VW06
1 Fault Found:
01592 - Air Quality Sensor (G238)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 229823 km
Time Indication: 0
Date: 2022.05.07
Time: 20:08:00
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag025 H05 0023
Revision: -------- Serial number: 003JX000BBMD
Coding: 000000000000000000000000000000003235
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 40D9BC5C5A0FFD4B8FF-8014
Seat occupied recognition:
Serial number: 5850000R1070300JCH
Serial number: 3575LRB406900TMO78DT
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB404P04QLQCGBE
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515RRB405900IUGK0MV
Passenger side rear thorax airbag crash sensor:
Serial number: 3525RRB405900IUGMPGA
Serial number: 3555NRB404V010DA8P47
Serial number: 3565NRB4053010DA698A
1 Fault Found:
9443091 - Driver's Side Airbag Crash Sensor
B1017 13 [136] - Open Circuit
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Mileage: 227997 km
Date: 2022.04.23
Time: 11:31:47
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815JJ70000Y
Coding: 000015
VCID: 313FE998E12564C3701-8064
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0031851
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H09 0231
Revision: 08240053 Serial number: 658081010593022
Coding: 836733022B00D705020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 47CBA7407F21CA734E5-8012
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000047716
Coding: 0001037500
GVL: FB0F40051D7F000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 3829D4BC02DFB58B37F-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650402415
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000108968644
Coding: 011D07200000453005080000
VCID: 3C21C8AC366799ABD37-8068
1 Fault Found:
02110 - Window Regulator Switch
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 9
Mileage: 229708 km
Time Indication: 0
Date: 2022.05.07
Time: 15:43:26
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0132616568
Coding: 0106123A28B9500080A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 172101933
Subsystem 2 - Part No: 1K0 951 605 C
2 Faults Found:
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 231257 km
Time Indication: 0
Date: 2022.05.28
Time: 16:18:17
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 231257 km
Time Indication: 0
Date: 2022.05.28
Time: 16:18:17
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000108976058
VCID: 3B23CBB033699E93DAD-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A1091700029
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 3537DD8815CD48E32C9-8060
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: --------------
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA108AC766759AB937-8028
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0006
Coding: 130000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0006
Coding: 130000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 080 D HW: 4G0 035 080
Component: Radio U SIRIU H54 0112
Revision: AB001007 Serial number: 029AN0C7502540
Coding: 020007020100000001
Shop #: WSC 02172 444 12510
VCID: 1F1B1F2087B1E2B3D65-804A
Part No SW: 7P6 035 664 HW: 7P6 035 664
Component: H-BN-NA H43 0319
Revision: -------- Serial number: 445I$0A7506662
Coding: 010200050040E1EE01022B0C00000003F0080101
VCID: 75B71D8855CD08E3EC9-8020
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H23 0045
Serial number: VWZ8Z9K29002HC
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
1 Fault Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 220200 km
Time Indication: 0
Date: 2021.11.25
Time: 13:39:10
Freeze Frame:
Text: MuGPS,Main,M,0,0,6
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000108983137
Coding: 011C07200000253005080000
VCID: 3A2DCEB43C53A79BC1B-806E
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000012581
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001002 Serial number: 00000134985858
Coding: 020D000000000000
VCID: 372BD7800F41BAF33E5-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H03000 Serial number: 525 PA8J081920
Coding: 0110001
VCID: 372BD7800341BAF33E5-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 09145444 Serial number: 278000206
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000108982560
End----------(Elapsed Time: 01:57, VBatt start/end: 12.1V/12.1V)-----------
Saturday,28,May,2022,17:46:14:50148
www.Ross-Tech.com
6C 6D 72
Coding: 001368
Revision: 00002001
Coding: B606200880
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 31
Mileage: 231257 km
Date: 2022.05.28
Time: 16:44:25
Coding: 004DBD
Coding: 035223
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 229823 km
Time Indication: 0
Date: 2022.05.07
Time: 20:08:00
Serial number: 357 RB4000000000004
1 Fault Found:
B1017 13 [137] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Mileage: 227997 km
Date: 2022.04.23
Time: 11:31:47
Coding: 000015
Coding: 0001037500
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 9
Mileage: 229708 km
Time Indication: 0
Date: 2022.05.07
Time: 15:43:26
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 231257 km
Time Indication: 0
Date: 2022.05.28
Time: 16:18:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 231257 km
Time Indication: 0
Date: 2022.05.28
Time: 16:18:17
Coding: 01040000
ROD: EV_ParkbA7.rod
Slave 3:
Coding: 130000
Coding: 130000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 220200 km
Time Indication: 0
Date: 2021.11.25
Time: 13:39:10
Freeze Frame:
Coding: 0110001
Coding: 0533314003
End----(Elapsed Time: 01:53, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Did you replace the sensor yourself? And then went for a drive and it didn't start?
Or did the dealer do this, you drove home, and now it doesn't restart.
Need way more info.
  • Helpful
Reactions: Mike in Anchorage
1 - 4 of 4 Posts
