1 - 3 of 3 Posts
Recently I noticed when locking my Treg with the FOB the red LED alarm light on the inside of the drivers door blinks 7 times fast, then blinks at what I think might be a faster rate than I remember it doing.
At first I thought it was from coding the battery for the BEM with my replica VCDS as I noticed that there were a few control modules that were missing the ASAM file or .rod file.
So I ordered a genuine Ross-Tech VCDS cable. This fixed the missing ASAM/.rod files but the LED alarm light still reacts the same when the Treg is locked.
Does anyone have any info on what the different blink patterns of the red LED indicate?
Latest scan using VCDS is below.
Wednesday,03,July,2019,00:29:38:40064
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 19.6.1.0 HEX-V2 CB: 0.4507.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: Private VIN# License Plate: NONEYA
Mileage: 134845km-83788mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
VIN: Private VIN# Mileage: 134845km-83788miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
15-Airbags -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CGRA) Labels: 03H-907-309-V1.clb
Part No SW: 03H 906 023 B HW: 03H 907 309
Component: 3,6 FSI ULEV2 H11 8643
Revision: M7H11---
Coding: 002A0012433600000000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM36FSI01103H906023B 002005
ROD: EV_ECM36FSI01103H906023B.rod
VCID: 211FE5B75140220FE57-8074
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 A HW: 0C8 927 750 A
Component: AL1000 AISIN 001 1824
Serial number:
Coding: 001368
Shop #: WSC 54587 001 104857
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: 2A0D029B2C76E157B4D-807E
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 G HW: 7P0 907 379 A
Component: MK25A H33 0421
Revision: -------- Serial number: 417400010EC010
Coding: 5B7613C349242554DAF4C89992D9A4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 41DF4537B100020F857-8014
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 H
Component: BCM2 2.0 H13 0208
Revision: 00002001
Coding: 09860000000000000000
VCID: 72BDDAFBC4A6E997CCD-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0510000041856011
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 0210000092414004
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 AA HW: 7P6 907 040 AA
Component: Klima 2 Zonen H18 0612
Coding: 4606200A80
VCID: 73B3DFFFBB3CE09FC7B-8026
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 D HW: 4H0 907 063 D
Component: BCM1 2.0 H11 0083
Revision: 15011002 Serial number: 00000000581650
Coding: 26081013943C7D010021180300005D0C431C660882010261000000020000
Shop #: WSC 12345 123 61029
VCID: 290FFD9729F0EA4FBD7-807C
Component: WWS 100705 31 0020
Serial number: 90243400100708103232
Coding: 0045BD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10037851
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000000107100091
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R026W06
Address 15: Airbags (J234) Labels: 7P0-959-655.clb
Part No SW: 7P0 959 655 A HW: 7P0 959 655 A
Component: VW10Airbag099 H05 0020
Revision: -------- Serial number: 003FH000LVMN
Coding: 000000000000000000000000000000003939
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 3FDB43CFC7F474FFF33-806A
Seat occupied recognition:
Serial number: 5850000R10317004NF
Serial number: 3575LRB405L6U4L25PA/
Crash sensor for side airbag: front passenger side:
Serial number: 3585LRB405J6U4L2E8N1
Crash sensor for side airbag: rear: driver side:
Serial number: 3515RRB40536T8MIB8H
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525RRB40536T8MIC0HW
Serial number: 3555NRB405B6OBGCE95O
Serial number: 3565NRB405B6OBGC9H8V
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815JG20001J
Coding: 000015
VCID: 313F15F70120928F757-8064
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0017759
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 M HW: 7P6 920 980 M
Component: Kombi H09 0231
Revision: 08140052 Serial number: 658100710593018
Coding: 837732022B00D705020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 46D5562B982E2537B05-8012
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000023910
Coding: 0001032600
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 382928D3E2DA43C7329-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650276717
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000006118150
Coding: 0058130000004001000001010101202020202121202020
Shop #: WSC 25038 444 92088
VCID: 34311CE3FE32A7A71E1-8060
Address 42: Door Elect, Driver (J386) Labels: 4H0-959-793.clb
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000105976241
Coding: 011D07205E00453005080000
Shop #: WSC 00017 666 02354
VCID: 3C2134C3D6626FE7D61-8068
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0131550612
Coding: 0106163A28B9509482B00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 090101718
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H05 0006
Serial number: WOO10189441
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H06 0006
Serial number: WOO10197833
Coding: 191100
Address 52: Door Elect, Pass. (J387) Labels: 4H0-959-792.clb
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000106166111
VCID: 3B2337DFD36C68DFDFB-806E
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A10618000AB
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 353721E7F5C8BEAF29F-8060
Slave 3:
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: --------------
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA1F4C39662AFE7961-8028
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0006
Coding: 130000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0006
Coding: 130000
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H51 0133
Revision: AB001007 Serial number: 471G+0A7513777
Coding: 020007020000000001
VCID: 2411ECA34ED237278E1-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 D HW: 7P6 035 664
Component: H-BN-NA H43 0706
Revision: -------- Serial number: 445G$0A7504549
Coding: 010200050040E1EE01022B0C00000003F00801010000000000
VCID: 392F2DD7D9505ACFCD7-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H23 0045
Serial number: VWZ8Z9K29000BU
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 134810 km
Time Indication: 0
Date: 2019.07.02
Time: 12:09:48
Freeze Frame:
Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 134810 km
Time Indication: 0
Date: 2019.07.02
Time: 12:09:46
Freeze Frame:
Voltage: 12.40 V
Address 62: Door, Rear Left (J38: Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000106117180
Coding: 011C07200000253005080000
VCID: 3A2D32DBDC5651D7C4D-806E
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000005901
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001002 Serial number: 00000131775465
Coding: 020D000000000000
VCID: 372B2BEFEF444CBF3B3-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H03000 Serial number: 525PA8-J050845
Coding: 0110001
VCID: 372B2BEFE3444CBF3B3-8062
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 09145444 Serial number: 168000257
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels: 4H0-959-795.clb
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000106116354
End----------(Elapsed Time: 02:08, VBatt start/end: 12.5V/12.4V)-----------
I'd suspect some previous tweaks you or previous owners made weren't accepted
03175 - Ross-Tech Wiki
03276 - Ross-Tech Wiki
The faults in the 5F module are from me updating the RNS850 firmware without being connected to the mothership. Very common.
Noticed the odd blinking of the LED after I tried recoding for the new battery. I even clicked yes when told the module was uninitialized so that the 12345/1234/2345 would be put in and the coding accepted without the error mesage.
1 - 3 of 3 Posts
