Haven't posted here in a while but have been a member since late '04. I have an early VIN 2004 V6 that I still love. Purchased platinum RealDriver warranty at delivery. Recently, dealer is giving me grief over a few extended warranty replacement items. I need your help in helping them negotiate with the warranty company. Your tips appreciated!
TMPS sensors -- on right side have gone bad. They replaced the left side 8 months ago under extended warranty and are now saying right side is not covered! Same exact defect now. Right side went bad shortly after left-side replacement. I gave them a lot of grief on this one!
Driveshaft -- they are replacing with no hassle after high-speed shimmy noticed.
The emergency brake handle broke off in my hand and they are telling me it isn't covered! I had the entire assembly replaced several times because it stops releasing properly, yet when the handle breaks off, they tell me it's not covered! This is NOT a trim item and not a wear item and therefore should be covered. I wonder if we should submit that the break is again not releasing properly, and that that's why the silly handle broke off!
Rear-window sunshade has come apart and they are tilling me, without even having checked, that this is not a covered item. It's not a trim piece and it is not a wear item; thus, I think it may be covered. Anyone have this problem?
Xenon bulb has begun to go out/flicker. I have seen some posts that these can be covered if the whole assembly is replaced. Anyone know the skinny on replacing the bulbs oneself if they are not covered?
Thanks!
Walker
Thanks!
Walker
