Hoping someone can help...i retrofitted an rns510 in my 2010 v6 TDI..latest firmware and maps.. all was working well...
I went to turn on the car and noticed the unit is just dead, no lights, nothing on screen, no sound..
i put the delta radio I originally had into the truck and it works no problem (so i know its not a fuse or wire issue)
hoping its not a dead motherboard on it.
any ideas on what I can check?
I used VCDS and all modules are find except no communication with the RNS510 (which was working perfectly with no signs of issues)
i am going to take the rns510 apart and check all the capacitors but hoping to get some guidance on what I can check or test
any help is appreciated
thx
It sounds like it is dead.
FWIW, it may be time to consider some of the Apple/Android friendly DDIN units that will fit into the area perfectly, and as a bonus, their facia design is extremely similar to the latest generation radio units. They are (predominately) plug and play and will offer a much more feature filled experience than the (ageing) RNS510 unit does.
The RNS is now longer subject to firmware updates (certainly for Euro/Aus-NZ) and no more map updates that I am aware of for the same regions.
There are threads on this forum for the Android unit and, here is an example I am referring to Volkswagen Touareg Android OS GPS Navigation Head Unit
Check to ensure it is compatible with your region for Radio frequencies etc.
had the android unit, didn't like it....just installed this rns510 unit 9 months ago and just did the high rear camera oem retrofit 2 weeks ago... I like the rns510 and how it integrates so want to keep it.
will see if I can revive it or look for a replacement/service it.
im open to any suggestions
crazy how it died like that without any symptoms.
