Re-screw the shaft bolt through the cv joint into the shaft and the joint will pop off. Then you can take the joint apart to clean and repack. When I have a CV boot failure and catch it soon, I will not always take the joint apart, but just put some fresh grease in and reinstall with new boot. The A student would probably take the joint apart and clean.
