1 - 12 of 12 Posts
I saw this post earlier but I guess things in the pic looked different than my engine compartment and that concerned me. I guess if it's a 4.2L the sensor is in the same spot, I'm hope that is.
Thanks.
You are correct, the post is referring to a AXQ engine V8, 2004- 2007.5. Your engine code is BAR, FSI engine V8
2007.5- 2009. If someone doesn't give you a location for the sensor by tomorrow, I will find it for you from my Bentley Repair Manual and let you know. Mtnride
Thanks.
tjlmbklr, engine speed sensor location for FSI V8, BAR engine code. Sensor is located on the bottom of transmission bell housing. Take off belly pan and you’ll see it, easily accessible. Hope the replacement of this sensor fixes your issues. IMG_1148.jpg
Reactions: nickyt
tjlmbklr, engine speed sensor location for FSI V8, BAR engine code. Sensor is located on the bottom of transmission bell housing. Take off belly pan and you’ll see it, easily accessible. Hope the replacement of this sensor fixes your issues. View attachment 222279
Thanks. This was a huge help.
No problem glad to help
Please give us an update after you install your new sensor let us know if your issues were resolved.
That was quick, simple install I presume, my fingers crossed for you as well.
1 - 12 of 12 Posts
