1 - 4 of 4 Posts
Considering going Malone Stage 2 soon then moving to a full delete after my annual inspection in October. I may want to return the vehicle to stock for sale or annually for inspections. What is the cost to remove and delete? Assuming it is the same cost to reinstall?
you can run stage 2 with all emission stuff installed. you might still pas MOT with the stage 2 tune, I would definitely give it a try.
downpipe and DPF or just one of them?
for the flash itself, you can do it yourself with flashzilla
Thanks. Definitely will be able to pass emissions with just stage 2 which is why I'm starting there. I've always wanted a deleted TDI so I'm considering that after I go to stage 2 for a bit
in that case, I would start with flashzilla and Tune stage 2 AND deletes and ask to get both tunes (with and without deletes). Dealers won't do it, but it is very easy with flashzilla if you go straight through Malone.
Rawtek sells DPF delete and claims installation in less than 2h
downpipe is also available, not sure how hard/long it is to install/remove it. Many people cut the downpipe as it is easier; not doable if you intend to re-install it later on.
1 - 4 of 4 Posts
