Ok-first off, I love this forum. It’s been fantastic in problem solving, but this is my first post/question.
Long story as short as I can make it- Got a low coolant notification. Could not spot anything in usual suspect areas and nothing on the ground so I topped it off. Got it again a couple of weeks later so I took a camera and took a better look. Lots of liquid around the oil cooler. I saw the posts here about coolant pooling in that area. I took it to the dealer (I have an unheated garage and January in Chicagoland…) who confirmed the oil cooler but insisted there was no coolant leak. I got the car back 4 weeks later with a new oil cooler and related parts. VW would not cover any under the warranty extension because the dealer would not say there was a coolant leak. Days after I got it back, coolant light. Argh.
So, the 1st Q I have is, if the egr cooler is leaking, will that all be going back into the recirculated exhaust or can some of it make it’s way down to the top of the V? It looks wet again, but it seems to be losing far more that what is pooling.
The second q I have is will the pressure test for the cooling system look fine even if the egr cooler is leaking? The answer I got from the dealer is that it passed the test so it’s not leaking (but it is…). They have had it for another week, did another pressure test and have not found a problem but they seem to be unwilling to consider the possibility that the egr system could be the source of the loss.
