1 - 16 of 16 Posts
Hi everyone my 2014 vw Touareg 3.0 v6 tdi is in having work done in the body shop as the car got backed into and broke the front light and slam panel they saying they need to remove coolant and a/c gas. Dose any one know how many litters of coolant it will need to refill I was told 7 litres then someone said that is wrong more like 15 litres any info would be great. I know it takes g12+ pink thank you very much for any help
The mechanic who's doing said work doesn't know capacities?
He is a body specialist and not a mechanic and has placed order for 10ltrs of coolant but I’m thinking it could be more and want the car back not wait another day for more coolant to arrive.
I'd be more concerned about having a body guy drain and refil such critical/sensitive systems vs not having sufficient coolant on hand.... You guys realize that you don't just pour in a/c refrigerant right? If sorting out the coolant capacity presents these challenges, properly refilling the a/c system.
Hi the company have a great reputation on the work also the a/c refill they call a company in to re-gas system. They are just charging £40 for the re gas which I thought was good
2012 180TDI
You don't use G12 straight, generally mixed between 33 and 50% G12 to water. Your 10 litres will make between 20-30 litres. The entire system also wouldn't have been drained, so a complete dry refill amount won't be accurate.
Discussion Starter #8
The coolant is a g12+ ready mix so I think it dose not have to be mixed with anything
2012 180TDI
If premix it doesn't have to be mixed. Capacity is 14l or so from memory for a complete fill. You likely won't have a completely fill, as there will probably be coolant left in the block, heater etc.
What's being done about the trans cooler?
Discussion Starter #12
Well today I called Vw and they have said about 14ltrs from empty also they told me to use g13 I don’t understand as I thought g12+. They then told me that as long as I don’t mix the coolants then everything wood be ok. Don’t no what u lot think
G13 is a later, better specification than G12+
1 - 16 of 16 Posts
