Hi All,
OK, doing upper and lower control arms on '04 Treg with Air suspension.
I finished the upper and all seemed to be going well on the lower until I encountered the front bolt on which the nut was rust siezed to the bolt. After heating it red hot more than once, finally got it out. As I have the tool, popping the ball joints was also easy.
Anyhow, after popping lower control arm ball joint I am now stumped as to how to actually remove it from the carrier (or whatever it is called) where it sits. I thought that once I had the bolts out of the control arm that I could maneuver the ball joint free but not even close. The top of the ball joint hits against the axle shaft and that general area well before I can lift it out.
It almost looks like you need to remove the asembly from the axle shaft. I did not remove rotor, caliper, etc. Was I supposed to?
Anyway, poor Treg is sitting in the air awaiting some knowledge to guide its owner (me).
Thanks,
Mike
Thanks,
Mike
