Respost of what I posted on VWVortex for those of you who don't make it there:
It only took me 4 months but I finally installed a permanent auxiliary plug and a 12V power supply in my center console box. Now all I need to do is get my MP3 player back from the repair shop and I can listen to 20 gb of music.
One end:
The other end:
I did a bad thing and didn't take pictures all the way through. I started to take pics and then in the middle stopped. Then took some at the end. I will post them below.
Here are the basic steps:
1) Remove light in box.
2) lift box out of console by front and back - it isn't screwed down. Note that there is actually a second box (see 2nd and third photos) in the center console held down by many screws and holding some of the console together. This doesn't get removed but some of it must be dremel cut away to make room for the 12V plug and audio plug.
3) Remove two screws in front of box - see photos
4) pop off wood section around cupholder - you will probably lose 1 or more of the 4 metal clips that hold this on. Be prepared to fish them out with a magnet.
5) Remove cupholder - lift it out. It snaps in from the rear.
6) Remove plastic frame on top of center console that holds front wood and all switches. Unplug all switches and other electrical devices.
7) Cut appropriate holes in secondary box.
8) Match up and cut proper holes in the inner box.
9) Run wires along inside of center console to front of center console and up behind radio. You will need to remove the radio and the lower plastic panel under the dash in the footwell area.
10) Take power from passenger fusebox and ground from where ever you can find it (use a solid chassis ground - don't tap into an existing ground).
11) Reassemble and you are done.
Took about 2 1/2 hours the first time. Probably could cut it down to 2 hours next time.
4 photos:
