1 - 4 of 7 Posts
MuTaJlaKo
Discussion starter · #1 ·
Hi, i have touareg 3,2 2004year. This morning i start to fill baby water pool with air from the car compressor under the passenger seat. I almost filled it when the compressor stoped working. Before that i was hearing the compressor and now i dont. I checked the two fusses in the left -27 and 48 i think for suspension and under the driver seat number 13 40apms. All look good.
any idea what else could be the problem or just the compressor is gone and i need to repair or change it.
Discussion starter · #4 ·
Now i drive it for a while about 1-2 km and the compressor starts but only for seconds. It has air for a while and stops again. May it is over heated and need to cool down because it is 31 degrees now :(
Discussion starter · #6 ·
@Capes 21:
For clarity the OP''s Touareg has air suspension so it does not have a separate 12v electric pump for inflating the spacesaver.
He has a flexible air hose that connects to the air suspension pump to inflate his tyres/spacesaver.
It sounds like the air suspension pump may need to be serviced using a rebuild kit.
Can that be the problem and the compressor not to start working ?
1 - 4 of 7 Posts
