Do you have a photo with the eyelashes off but the LED on?
As I see it, there are two LEDs that come on by default as the DRLs (per headlight assembly). One is the “eyelash” or line on the bottom of the assembly (and wraps up the side a bit) and the “u shape” that wraps around the main headlight.Do you have a photo with the eyelashes off but the LED on?
Same. Driver's side intact, Passengier side eyebrow failed a year ago, center U running light has now failed.My eyelash failed on passenger side. I don’t know if it’s coincidence or associated, but the light with the burnt out eyelash is also much brighter. Is this consistent with others’ experience? Really frustrating, my wife was following me in the Touareg the other night and it looked like only the DRL was on for the driver side. I dread dropping $$$$ to fix it.
also curious if anything can be done to turn the working eyelash off with OBDeleven?
Yes it can be.My eyelash failed on passenger side (2017 Wolfsburg). I don’t know if it’s coincidence or associated, but the light with the burnt out eyelash is also much brighter. Is this consistent with others’ experience? Really frustrating, my wife was following me in the Touareg the other night and it looked like only the DRL was on for the driver side. I dread dropping $$$$ to fix it.
