1 - 6 of 6 Posts
Lazarusz
2012 V6 TDI Sport
Discussion starter · #1 ·
So for some reason, the comfort windows decided to not work anymore, that feature where you hold the lock/unlock button on your keyfob and it rolls the windows up/down.
Previously I didn't have this feature in my car and had enabled it through OBD11 android app and it worked fine. I still have this option in my car menu and have both front and rear windows enabled. I tried both keys, turning the feature off and back on again, still not working. Any suggestions? I only have the OBD11 thing, no VCDS. Also to mention that I had replaced the car battery a couple months ago if that's important.
2012 TDI
237506
Try the drivers window first.
Press the button to force the window down and DO NOT LET GO until you have counted to 5 [seconds].
Then, send the window up and repeat the hold process when the window reaches its travel limit.
Now. Try bringing the window down with a quick press of the button. Works? Good. It’s because you have reset\forced the system to know it’s limitations. Now rinse and repeat for the other windows.
If this doesn’t work you need to get a VCDS scan of the car to find the fault.
Reactions: Lazarusz
Discussion starter · #3 ·
Unfortunately doesn't work :(
Tried all four windows.
After some researching I'm pretty sure it's all because of the battery change, now the question is how do I get the feature restored..:unsure:
Maybe my instructions weren't 100% correct.
try:
1) Roll window down completely by holding down the switch
2) Release switch then hold down again for 3 seconds
3) Roll window up completely by holding up the switch
4) Release switch then hold in up position for 3 seconds
That should bring the one touch functionality back to life.
Reactions: Lazarusz
Discussion starter · #6 ·
try:
BINGO!! Thank you so much! :)
1 - 6 of 6 Posts
