1 - 9 of 9 Posts
I ran a check engine test and got 2 codes.
P0171 & P0174
Bank 1 & 2 lean
Do i need to clean or replace my mass air flow sensor? Please help, Thank you.
Are we expected to guess what vehicle and engine comvination you have?
Also a copy of a scan log would be a great help.
P0171 & P0174
Bank 1 & 2 lean
As said, a post of the scan and vehicle details would be helpful. MAF is a "no brainer" because it costs nothing and is easy to try (make sure you use a proper MAF cleaner), other than this it could be a number of things from a clogged fuel filter all the way up to dodgy injectors or a failing high presure fuel pump.
1 - 9 of 9 Posts
