Hi. First, let me thank everyone for this forum, I have been reading the threads here for years... finally joined in
My 2006 V6 Gas Touareg (132,000 KM) has the check engine light on and ESP light on. I plugged in the scanner and it reads the following codes:
P0101
P0420
P0430
P0068
The truck isn't pulling to either side, so guessing alignment still ok but exhaust smell rich, consumption is way above average and the drive seems unusually heavy. The ESP light starting coming on every now and then (in non-slip surfaces) and soon after a front brake job, plus now heavy snow in Montreal, the light is always on!
Can someone please help? For the check engine, how do I determine the problem (sequence to troubleshooting)? And ESP, can it be just an alignement that I need, but what should I check before doing that, or to ID the actual problem? Actually, can that switch be stuck? My kid's apple juice spilled on the center console about 2 years ago and ever since it's been a little sticky. I ruled that possibility out because I figured the ESP is on by default as soon as you turn on the engine, right?? And it's been such a long time since that incident!
Any help is greatly appreciated! Thanks!
P0101
P0420
P0430
P0068
