1 - 7 of 7 Posts
Vehicle Details
Year: 2004
Model: Touareg
Engine: 3.2 V6
Miles: 114,000
Suspension: Spring
Diagnosis:
I have replaced all 6 coil packs (pre & post VW Recall in the past year). Installed new NGK Spark Plugs and my check engine light is still flashing these codes.
Codes that keep coming back:
P2189 - System Too Lean at Idle Bank 2
P2187 - System Too Lean at Idle Bank 1
P0300 - Random Multiple Cylinder Misfire
P0305 - Cylinder 5 Misfire Detected
Can anyone assist me?
A Fault MAF sensor can cause these codes. You need to monitor the short term and long term fuel trim as well as the MAF readings at idle,part throttle and under full load.
Is it always the same codes? Always cylinder 5 that records a misfire?
It's not always Cylinder 5. I've had 1-6 show up; random order and sequences.
I will check the MAF. That's good to know.
Any other ideas?
Hi:
I have a similar problem but with some more error codes. It's a 2004 Touareg V6 and I've recently changed the all 6 coils at the dealership. The check engine light is always on and the car slight shake when idling in park.
codes are:
Address 01: Engine
Controller: 022 906 032 BF
Component: MOTRONIC ME7.1.1G 9779
Coding: 0000133
Shop #: WSC 05246
13 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - Lower Limit Exceeded - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 002 - Lower Limit Exceeded - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 002 - Lower Limit Exceeded - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 002 - Lower Limit Exceeded - Intermittent
18711 - Leak in Air Intake System
P2279 - 002 - Lower Limit Exceeded
16685 - Cylinder 1 Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
18322 - Pressure Sensor for Brake Boost (G294): Implausible Signal
P1914 - 008 - Implausible Signal
16689 - Cylinder 5 Misfire Detected
P0305 - 008 - Implausible Signal - Intermittent
17559 - Long Term Fuel Trim Additive Air Bank 1: Range 1: System too Lean
P1151 - 001 - Upper Limit Exceeded - Intermittent
17497 - Mixture Regulation: Bank 2: Range 1: Lean Limit Exceeded
P1089 - 001 - Upper Limit Exceeded - Intermittent
17498 - Mixture Regulation: Bank 2: Range 2: Lean Limit Exceeded
P1090 - 001 - Upper Limit Exceeded
17560 - Long Term Fuel Trim Additive Air Bank 1: Range 2: System too Lean
P1152 - 001 - Upper Limit Exceeded
Readiness: 0000 0001
Thank you,
u think its the pcv valve? I already changed it 2 years ago!!
Discussion Starter · #6 ·
Yes. It broke down on me and would not drive or keep running. At the stealership at a cost of $95 for a tow and $400 for parts and labor :mad:
I wonder how many times the "mad" smiley has been used on these forums to show respect for these vehicles...
1 - 7 of 7 Posts
