1 - 4 of 4 Posts
Volcomdrift
Discussion starter · #1 ·
Hi!
I have a 2004 touareg v10 TDI and the check engine light does not work. Even if i take off connectors on Air mass sensors etc to create fault codes. I can read out these fault codes i create, but no MIL. No fault codes eighter.
New original software in both ECU.
Checked LED in sntrument cluster. it workes, when i try it with current.
Anyone have seen this before?
Discussion starter · #3 ·
No, it doesent.
Wierd thing is when i read OBD 2 protocol, readiness in vcds, all of the monitoring system shows Not installed.
ive checked the wires under the carpet on driver side, the carpet is wet, but the wires looks ok
There are a handful of V10 people here, hopefully they can pitch in
1 - 4 of 4 Posts
