To all,
I am currently stationed in Islamabad Pakistan, and my 2006 Touareg V10 arrived completely dead. Today, I changed the batteries and I figured there will be a lot of fault codes. After the first run, I cleared the codes and ran again.
When I am running my Vag Com, I get the following pop-up dialog box Internal ROD error - How do I correct this? (see attached photo)
The below is my scan after initially clearing all the faults after installing the new batteries
I suspect I need to to the basic steering setting to 00778 faults, but how do I clear up the internal ROD errors, and 01299 fault code.
There isn't any VW dealers in Pakiland, so any help or solutions would be helpful.
Thanks in advance for your assistance
Joe
Friday,11,November,2016,15:55:10:21872
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
Ross-Tech: Home
VIN: WVGPT77L16D055679 License Plate: 11112016B
Mileage: 117860km-73234mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L16D055679 Mileage: 117860km-73234miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG000AGMª8472
Revision: --H02--- Serial number: VWZ3Z0E6407718
Coding: 0060575
Shop #: WSC 31414 000 00000
VCID: 61C95C01BB1CDA4AD3-5122
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels:
VCID: 55A178D1BF5426EABF-5122
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
VCID: 3D71C0716724DEAA97-5122
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 HW: 5WK 484 92
Component: 29 Kessy 6700
Revision: 67005614 Serial number: VWZ3Z0E6407718
Coding: 0131304
VCID: 70EF294560F663C24C-5122
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77FD1259059834FA8D-5122
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 T
Component: CLIMAtronic 2+2 4222
Coding: 0021030
Shop #: WSC 20108 444 54725
VCID: 4581A8910FF4966ACF-5140
Subsystem 1 - Part No: 7L6 907 049 E
Component: CLIMAtronic FOND 0400
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3001
Coding: 0111836
VCID: 479DA29935F8847A3D-5122
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSª8472
Coding: 0060575
VCID: 61C95C01BB1CDA4AD3-5140
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0007209?
Coding: 0012341
VCID: 285F012598A66B02D4-5140
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010032
VCID: 4487B59504CEAF62D8-5122
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 R
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0007131
VCID: 489FA1A538E68B0234-5122
Address 18: Aux. Heat Labels: 7L6-819-008.lbl
Part No: 7L6 815 071 D
Component: Standheizung E1MAC
Coding: 0000100
VCID: 3365E649516018DA71-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F0DFA792DA80CBAC5-5122
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: 66C34F1D5232BD7226-5140
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 3663DF5D42120DF256-5122
1 Fault Found:
004 - No Signal/Communication
Address 36: Seat Mem. Drvr Labels: None
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0044
Coding: 0000101
VCID: 50AF89C5C0B643C26C-5122
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: 67DD42195538A47A1D-5122
Part No: 7L0 959 933 J
Component: HSG 5115
Coding: 0000085
VCID: 4385B68901C0A85AE1-4AFE
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 E
Component: Radio 0044
Coding: 0014472
VCID: 3561D8515F1406EA5F-5122
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C77CD757C3ED7A2A0-5122
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
VCID: 387FD1654806FB8244-5122
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J5X0588
Coding: 0000101
VCID: 72EB234D6EFA51D2BA-5122
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 124
Time Indication: 0
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 3979D461730CE28ABB-5122
End-------------------------(Elapsed Time: 08:36)--------------------------
I believe a VCDS ROD error means some part of the VCDS database containing information about your vehicle is missing. Maybe try reinstalling VCDS.
I have occasionally had mysterious changes occur on the options page that prevented communication. So I would check there. Certainly wouldn't hurt to uncheck UDS for our 2006's.
So I did routine VCDS scans on my Touareg & GTI today. VCDS updated itself first. Then it gave me a couple of those ROD errors on the GTI. Never seen that before. I suspect VCDS software bugs.
I updated my software again and ran the scan all was good and I was able to make the basic settings change and all the lights on my dash cleared. I love my VagCom. It has paid for itself for me
