1 - 4 of 4 Posts
My center console latch won't secure, causing the top to randomly open. Right now, it's crudely taped shut lol. Is there a replacement piece? Anyone else had this happen?
So complete opposite from your other issue. I would say as I did about your glove box, bad latch and needs replaced. Doubt the current one is fixable.
I know lol, pure irony. I couldn't find a latch anywhere on the web, and I read another post, that some guy spent way more than he should have fixing the latch, and after $500 later, it was repaired.
Broken center console latch
After driving mine for almost two yers with a black rubber band around it, I used an easy fix, I cut two pieces of magnetic business cards (the one you stick on a fridge) and two pieces of metal strip and glued them in. That worked.
You can also check European Tuning by Malone and JR AutoTuning
z747pilot
1 - 4 of 4 Posts
