okay, I couldn't wait... My module accepted the Cayenne B0 coding without any issues. Went out for a drive and these are what I observed.
1. shifting point is higher now, very noticeable in 1st and 2nd gear, it is now shifting around 3k rpm with light throttle.
2. gas-brake-gas transition is much better. (Remember accelerating from an empty stop sign? yep) Clutch grabs much quicker. There used to be a 1 second pause when stepping on the gas after braking. In the past, I could apply more pedal pressure to 'force' the clutch to grab, but that resulted in 1 gear kick down and sudden acceleration which is not necessary nor very comfortable. It is now easier to feed the power in.
3. too much engine brake, or maybe the transmission is trying to learn something...
4. point 4 is the reason I decided to try this. I recently installed a chip and smaller pulley, with added torque, my transmission shifts funny at red line. It always pauses, throwing me forward, and then the whole car, not kidding, jumps forward after grabbing the next gear. Now it shifts like DSG at redline, not as quick as DSG but definitely faster than before. Crisp and smooth. I'm not sure what the new coding does its magic, I suppose might still be improved clutch clamping speed, or simply just stopped waiting 1 second before doing anything... It surprised me since I wasn't expecting to solve this problem with a simple coding.
This should also improve VR6 and TDI, who doesn't want a faster transmission?
as always, try at your own risk! I only drove 5 minutes with new coding, I will report back for long term effect.
