1 - 15 of 15 Posts
Coveted Porsche Cayenne S "Green Dot" Front Sway Bar Porsche Part# 955-343-701-70, Cayenne S Front Springs (500#) and Rear Springs (340#) and matching Spring Seats. Springs can be cut to your desired ride height. $500 + shipping. For faster response email me at mslerner2002 at gmail dot com Parts located in northern VA.
Discussion Starter #13
These 2010 Cayenne S springs WILL definitely fit the Touareg T3. I had them installed on a 2015 TDI. However, unless you want to raise your vehicle approx. 1.5" - 2", you will want to cut them. These springs are 30% stiffer than the OEM Touareg TDI springs. If you were lowering your T3 and didn't want the sloppy ride of the stock shocks with the H&R Sport springs, these springs would be the way to go. Then again, if you have the Bilstein B6 dampers, it would be even better, however, Bilstein doesn't recommend the B6 with lowering springs.
1 - 15 of 15 Posts
