1 - 14 of 14 Posts
Hello Everyone,
I have a 2011 Touareg TDI and have found a full set of older Cayenne 17" 10 spoke rims for $100.
The tire options for these rims will fit my off road and snow needs much better than my stock 19's and at a lower price.
I was wondering if there will be any fitment issues as I saw someone with a Q7 TDI who had the same rims and they had to grind the calipers to get them not to rub.
All feedback is appreciated.
Thank you
I have them on my 2011 treg. With Falken wildpeaks. 265 65 17. It's cosy around the front brake caliper, but nothing touches.
Thank you! Is yours a TDI as well? I thought I heard something about them having bigger brakes.
In Oz we have 150kw and a 180kw, 3.0TDI. I have the 180kw version, I'm not sure about bigger front brakes, but regardless, the rims fit, no drama at all.
I'm the Q7 with em, they should fit a Treg unless you upgraded it to Brembo 18Z.. I believe you got 17Z calipers, which they should fit.
I haven't upgraded the breaks and they look factory to me so that's great news!
Thank you Sir!
Per the t3 tire thread, you'll want to be sure the tire store uses low profile weights when they balance them, otherwise you're gtg.
May I ask where you found such a good deal? I'm looking for the same wheels.
Thanks!
Discussion Starter #9
Thanks!
My local Craigslist, I have since bought the rims and I'm in the process of getting tires for them but everything was legitimate with the deal!
Discussion Starter #10
Thank you all for the advice they look great and come with a ton of benefits for where I live I couldn't be happier with this decision!
239372
What tire size did you go with? They look good!
I got the same wheels (2006 Cayenne, 17" Victor Zehn) and did a test fit over the weekend. Its very snug around the front caliper, about 3/8 to 1/2" clearance on the rears and was thinking it might be too tight. Good to know that they can be fitted without issues.
Did you use spacers on your setup? I am in the process of painting mine Black.
Discussion Starter #13
No spacers were needed. I had a shop mount them and they didn't report any issues.
I've had them on for 2 weeks now and couldn't be happier!
Here's a quick review of what its been like in the past 2 weeks
Tire and size: 255/65/17 Goodyear Wrangler all terrain adventure with kevlar
I went with this size as it was the best size to price ratio and I wanted a pretty meaty tire as I do a lot of off road and it snows a decent amount where I live.
The aggressive tread does have a bit more road noise but nothing irritable.
I noticed there was a considerable weight difference with the OEM 19's being considerably heavier (about 5lbs per wheel) to carry than the 17's both with tires
I feel breaking and acceleration have been improved slightly as there's less weight to turn and stop, I also feel the weight difference would also improve MPG but I haven't done any calculations to prove it.
I do notice in hard cornering its a bit softer but not to the point where you'll need to change driving habits unless you drive like you're going for a record lap time.
The ride itself has improved in comfort especially on a rough road and going over bumps.
With that size I did gain about a 1/2" in ride height so the speedo is about 2 mph off at 75 mph indicated (75ind = 77act) but there's no rubbing with the larger size so I see it as a plus.
The price difference for tires was huge I was looking to replace the 19s and was quoted about $1100 for "decent" tires the goodyears were marked as "best" and were $680 with installation.
I wasn't sure of how this would turn out when I was making the switch but I am blown away with how it looks and preforms.
Please let me know if I missed anything or you have any other questions.
Thank you,
1 - 14 of 14 Posts
