1 - 2 of 2 Posts
Wonder if someone can help me.
I have a passenger door sensor that remains open - when door is closed. This actually has a big impact -
1. one that annoying chime as it thinks the door is open
2. When car is off and parked, the internal and trim lights remain on.
3. Alarm engagement - as it thinks the door is open.
So here is my question - even though the door actuator works fine, just the sensor that sends signal that door is open is faulty. I dont want to change the whole unit just for that..
Question : Is there anyway i disable that door with Vag.com or other way to let the computer know the door is closed ?
If this was a simple push button with door close, i would join the two wire together which would represent the door is closed.. unfortunately this is all contained within one unit, which is a nightmare to get to considering the internal skins with this model.
Also where could i find wire diagram for the door actuator ? does anyone know...
Thanks so much in advance...
If you purchased your VagCom from Ross Tech, ask the folks there. Their customer service is pretty good and they may be able to give you a quick yes or no answer. Otherwise you may have to experiment.
1 - 2 of 2 Posts
