1 - 20 of 29 Posts
I switched the air suspension over to a conventional coil over suspension on my 06 touareg. Wanted know if there is anyway to totally disable the warning lights through the Vag-Com?
Have you asked Ross-Tech?
You might want to browse the allroad form on quattroworld. A number of members have swapped out the allroad air suspension, and the controllers in the allroad and Touareg are somewhat similar.
Administrator
After coding for steel in all relevant controllers and after you have unplugged the air susp module, recode the gateway controller (don't change the code, just open, then save the existing code). This should force the gateway to relearn the controllers, see that there is no air susp controller.
Discussion Starter · #7 ·
Thx for all the advice guys!!!
I will follow your instructions and hopefully that solves my problem. Thx again!
My allroad air suspension is very different from Touareg. They both go up and down, but ride adjustment and auto return are lacking on the A6 allroad. The air system won't fill your tires or beach toys either.
Discussion Starter · #9 ·
Any idea where the air suspension module is located? I took out the 40amp fuse located under the seat so the compressor wont constantly run but I have no idea where the module is?
Administrator
Right rear compartment under cd changer. It's mounted in the vertical position.
Hey
I just had a thought what did you do with your air struts?
I may be very interested in buying the front LHS, obviously the drivers side for those who drive on the wrong side of the road. :giggle:
Regards
Drag
Discussion Starter · #13 ·
Hey
Regards
Drag
I'm actually going to hold onto them for awhile just in case i want to switch back. Thx for the interest thought.
Discussion Starter · #14 ·
Ok I FINALLY got around to disconnecting the air suspension controller and recoding the car with the vag com. It worked and I no longer get the suspension warning light on dash BUT now the headlight leveling sensor is activated and more importantly the ESP is disabled. Maybe there is a relay I can pull instead so I can retain ESP? Ill try and find a wiring diagram and see what I can find. I wanted to give you guys an update and thx again!
Administrator
What codes is it throwing now? Post a full scan. I'm thinking you have missed a controller.
Discussion Starter · #18 ·
Here is a full scan I did yesterday. I put asterisk next to the fault codes.
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
Mileage: 98400km-61142miles
Address 01: Engine Labels: 077-907-560-AXQ.lbl
Part No SW: 4D0 907 560 DF HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Revision: 00000000 Serial number: VWZ3Z0E6349847
Coding: 0007875
Shop #: WSC 31414 000 00000
VCID: 6DD1E97177028956AA-5140
***1 Fault Found:
18005 - Powertrain Databus
P1597 - 008 - Missing Message from Level Control System (J197)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 98405 km
Time Indication: 0
Freeze Frame:
RPM: 682 /min
Load: 27.0 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 36.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.843 V
Readiness: 0010 0101
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 DB
Component: AL 750 6A 0742
Coding: 0004136
VCID: 71E9F5016B3A6DB68E-5122
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014594
Shop #: WSC 08091 444 64448
VCID: 3D71193167E2D9D65A-5140
***1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 HW: 5WK 484 92
Component: 0E Kessy 6700
Revision: 67005514 Serial number: VWZ3Z0E6349847
Coding: 0131304
VCID: 70EFF005603064BE81-5140
Component: ELV XXXX
***1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77FDCB19055E338640-5140
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 L
Component: CLIMAtronic 2+2 4018
Coding: 0020030
Subsystem 1 - Part No: 7L6 907 049 D
Component: CLIMAtronic FOND 0400
***1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0105694
VCID: 468376DD32349A0E0B-5140
***1 Fault Found:
00907 - Intervention load Management
000 - -
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 01 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0001817:
Coding: 0012337
VCID: 285FD86598606C7E19-5140
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 418965C11B1ABD363E-5140
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981
Component: KOMBIINSTRUMENT RB8 3135
Coding: 0005231
Shop #: WSC 08091 444 85725
VCID: 76E3C61D02544A8E5B-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 458171D10F32911602-5140
Address 22: AWD Labels: None
Part No: 0AD 927 755 AJ
Component: TRANSFERCASE 0100
VCID: 0305AFC941866F266C-5140
***1 Fault Found:
02409 - Brake for Differential Locking Motor
012 - Electrical Fault in Circuit - Intermittent
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: 66C3965D52F4BA0EEB-5122
***1 Fault Found:
00492 - Body Pitch Angle from Level Control Module
008 - Implausible Signal - MIL ON
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 C
Component: SG-Quersperre 5020
VCID: 387F082548C0FCFE89-5140
Address 36: Seat Mem. Drvr Labels: None
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0049
Coding: 0000101
VCID: 50AF5085C07044BEA1-5140
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: 67DD9B5955FEA306D0-5140
***1 Fault Found:
Part No: 7L0 959 933 F
Component: HSG 0300
Coding: 0000085
VCID: 3F8D63396DEECBC648-4B1E
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
***3 Faults Found:
01134 - Alarm Horn (H12)
000 - -
00131 - Outside Door Handle Illumination/mirror Light Driver Side
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 456
Component: 08K Audioverst. 0105
Subsystem 1 - Part No: 7L6 035 456
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component: Radio 0049
Coding: 0014062
Shop #: WSC 08091 444 52595
VCID: 31693501ABBA2DB6CE-5140
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000855
Shop #: WSC 31414 000 376832
VCID: 3C7714357CF8D0DE6D-5140
Subsystem 2 - Part No: 1K0 955 559 R Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 010 1010
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000001
***2 Faults Found:
02564 - Trailer; Left Tail Lamps (M60)
011 - Open Circuit
Freeze Frame:
Count: 0
Count: 0
02562 - Trailer; Brake Lamps
011 - Open Circuit
Freeze Frame:
Count: 0
Count: 0
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J540333
Coding: 0000101
VCID: 72EBFA0D6E3C56AE77-5140
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 K
Component: DACHDISPLAY 0538
Revision: 00700538 Serial number: 2009289.06
VCID: 3F8D63396DEECBC648-5140
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 39790D2173CAE5F676-5140
***1 Fault Found:
00434 - Left Front Inner Parking Aid Sensor (G332)
014 - Defective - Intermittent
End-------------------------(Elapsed Time: 09:04)--------------------------
1 - 20 of 29 Posts
