1 - 20 of 105 Posts
My '03 Touareg is the 7LA model
With a VR6 3.2L petrol AZZ engine
If i take out the inlet camshaft position hall sender G40
And make shure that it remains connected to
earth (T121a/ 108 at J220 Motronic control unit),
power supply (T121a/ 98 at J220 Motronic control unit) and
signal (T121a/ 86 at J220 Motronic control unit) wires
Arranging that i can probe the wires with a multimeter
With the ignition on, in normal conditions and with a fully loaded battery, does anyone know the voltage i should read
Between earth and power supply
Between earth and signal wire in rest
Between earth and signal wire while metal in front of the hall sender
Please rescue me ;)
Hi TRespect,
Is this test VR6 specific?
Because different engines = different voltages and difference in pull or drop
I'll have to wach the vid some more times ;)
Also i have not many electronical devices, thats why i would like to start measuring using the ECU at first
This is how i have set it up, hoping i could start easy
Problem started out as longer cranking and has evolved to a no start
I can smell that engine gets petrol and from time to time he gives a little puf as if he wants to start
G40, G163 and G28 i replaced
All codes i get have to do with camshaft position sensors
Discussion Starter #9
I will make and post a new scan asap!
Wouldn't there be detailed info to be found about what voltages the ECU sends to the switches and what change in voltage the signal wire makes when the switch switches?
Would be so simple and fast to check ...
Discussion Starter #11
Tu habites en France :)?
I will do a scan tomorrow and post the result
The car has several problems but getting the engine to run again seems to be the most urgent ...
I really love it, so i will hang in there and i will do some studying about VCDS
Ouiii
Yes do the scan as the problem might be hidden in another error.
The fuel system should be on your list.
Try the check procedure in the video.
Listen to the pumps and measure the voltage.
Discussion Starter #13
Ma grand-mère était Française par naissance et j'ai habité chez elle pendand quelques années
Even so, Englisch will work better for me here ;o)
Ok, i'm going to put te switches back in place and let VCDS do it's work!
:smile2:
Yes. Check the vcds measuring blocks link above to see what you need to log. But do check the fuel pump too. Easy to do.
Discussion Starter #15
I'm about to let VCDS scan the car, but since my G40 sender was still removed i had to put it back in first
Taken the opportunity to do some more testing first
So with te sender removed, but attached to it's connector by means of test leads
And ignition on
I get +/- 4,98V between earth and power supply
And +/- 10,6V between earth and signal wire
When i bring metal close to the sender the voltage between earth and signal drops to 0,03 and goes back to +/- 10,6 when i take the metal away
This i can repeat as much as i want
So far it looks like normal behaviour to me, besides of the fact that i don't know if the voltages are as supposed
BUT ... when i put the sender into the engine, even before tightening, the signal always drops to 0,03V, whatever position i put the sender wheel in
(looking with a mirror and turning the crankshaft)
And this cannot be normal, since this way the ECU doesn't get any info about changing positions of the inlet camshaft ...
Ps.:
1) the picture is NOT my engine :)))
2) when i do some cranking, i can smell petrol and i can hear a pump buzzing, zo petrol pump 1 seems to be working
(measuring the pump is not so easy because there is a wooden floor in the rear of the car ;)
Discussion Starter #16
Some details which i think are important in order to interpretate the results the correct way:
The car runs on LPG, but this only kicks in as soon as the engine has warmed-up a little
(at this moment i have even switched it off, just in case)
The radio (wich is not original) isn't working
The car has only the 2 front seats and for leagal reasons the rear seats and buckles are removed
(so this will also give some errors, i only recently got it, so these are things i have to arrange as soon as it is driving again :eek:)
Also: i think i will have to do a new scan tomorrow after cranking the car for a while, because i erased the engine DTC's a while ago before starting to work on it
I hope it is not a problem: next to the scan that has been made today, i will attach a scan which i made a while ago: at that time the car needed long cranking,
but at the end it did start at that time, driving was still great
Perhaps we can already learn something (especially me: newbie, sorry) from this one
Just in order to be 100% complete: since it stopped running i have replaced senders G40, G163 and G28
And also (was already planned): waterpump, front crankshaft seal and polybelt
Today:
Friday,15,March,2019,17:26:49:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ3D006640 Mileage: 173210km/107627miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BE HW:
Component: MOTRONIC ME7.1.1G 0008
Coding: 0000133
Shop #: WSC 02402 202 05928
VCID: 4FA76DE5DDC60D1
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 A
Component: AL 600 6Q 0360
Coding: 0004136
VCID: 2C5D1A698C10169
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent - MIL ON
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 A
Component: ESP ALLRAD MK25 0105
Coding: 0014337
Shop #: WSC 31414 000 00000
VCID: 377735054556A51
1 Fault Found:
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 131 T HW: 5WK 470 21
Component: Kessy 6120
Coding: 0000232
VCID: 32610411AE34409
Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Part No: 7L6 907 040 D
Component: CLIMAtronic R/L 0302
Coding: 0001020
VCID: 31630B1DAB327B1
4 Faults Found:
002 - Lower Limit Exceeded - Intermittent
01592 - Air Quality Sensor (G238)
014 - Defective
01336 - Data Bus for Comfort System
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2701
Coding: 0100452
VCID: 448D52C90480FE9
2 Faults Found:
00907 - Intervention load Management
000 - -
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 B
Component: 4 Airbag 8.4E+ H07 0641
Coding: 0008244
Shop #: WSC 00000 000 00000
VCID: 2241F451FED4D09
5 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
001 - Upper Limit Exceeded - MIL ON
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
002 - Lower Limit Exceeded - MIL ON
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
011 - Open Circuit - MIL ON
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
011 - Open Circuit - Intermittent
014 - Defective - Intermittent
Part No: 7L6 953 549 B
Component: Lenksäulenmodul 3201
Coding: 0000011
VCID: 3E7920216A6C949
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 880
Component: KOMBIINSTRUMENT RB4 2601
Coding: 0007111
VCID: F4ED420994A08E9
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0E54E19E0B8B29
1 Fault Found:
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F071D252DE65D1
Part No: 7L0 959 933 C
Component: 4L HSG 3214
Coding: 0000065
Shop #: WSC 03816 202 82061
VCID: 3C7D2A297C70869
Part No: 7L0 959 701
Component: Tuersteuergeraet FS 0101
Part No: 7L0 959 702
Component: Tuersteuergeraet BF 0101
Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0101
Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
Part No: 7L0 907 719
Component: Neigungssensor 0018
Part No: 7L6 951 171
Component: A Innenraumsensor 0019
11 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00323 - Vehicle Inclination Sensor (G384)
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000255
Shop #: WSC 131071 1023 2097151
End ---------------------------------------------------------------------
Discussion Starter #17
Earlier:
Sunday,14,October,2018,22:10:34:32264
VIN: WVGZZZ7LZ3D006640 Mileage: 172580km/107236miles
Coding: 0000133
3 Faults Found:
16725 - Camshaft Position Sensor (G40)
P0341 - 004 - Implausible Signal
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl.
16955 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Readiness: 0010 1101
Coding: 0004136
1 Fault Found:
Coding: 0014337
Coding: 0000232
Component: ELV XXXX
3 Faults Found:
00457 - Control Module for Network (J519)
Coding: 0001020
3 Faults Found:
014 - Defective
Component: 2701
Coding: 0100452
2 Faults Found:
000 - -
Coding: 0008244
3 Faults Found:
Coding: 0000011
1 Fault Found:
Coding: 0007111
1 Fault Found:
Coding: 0000006
1 Fault Found:
Coding: 0000065
3 Faults Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
Coding: 0000255
1 Fault Found:
01305 - Databus for Infotainment
Too many errors related to voltage. What about the battery?
You need charge the battery, erase the code the crank and scan.
I don't know about the camshaft sensor but the knock sensor for example has a specific torque. Check this kind of detail.
1 - 20 of 105 Posts
