I have a question about the cam chain tensioners, I have the car 2 months without using and changed the timing belt, water pump and pulley’s, everything perfectly en time, I rotate the engine about 50 times and the tensioner on bank 1 works fine the one on bank 2 opens a little bit,they fill with oil when I rotate the engine or what can be the problem, the plastic shoes are all fine.
