1 - 20 of 61 Posts
Revised as of Jan 03, 2015
These rates for Touaregs!
Just a note. These rates for 2011 and 2012, and 2013 and 2014, and 2015 Touareg's!
Revised as of Jan 03,2015
Chris here from Burlington VW in Burlington, NJ
The VW Drive Easy extended service contracts have changed as of Jan 01,2008
They have now combined the new car extension w/ the used car extension and
have come up w/ one main plan.
Now the time starts the day you sign up and the miles you choose are on top
of what you allready have!
They still have the same verbage in the new contract as far as coverages
that will be explained here:
> Allthough I am open to all coverages, I would reccomend the Platinum
> coverage as it is an exclusionary warranty vs an inclusiuonary warranty!
> These quotes are w/ a std $100 deductible.
> Should you want a $0 deductible, please add an additional $230-$517
> depending on the terms you choose!
The $100 std deductible is per visit, NOT per complaint!
> This extended service contract is valid at ANY VW dealer and the dealer
> gets
> paid thru their parts and warranty dept.
> This warranty is also valid at authorized shops and they get paid thru a
> credit card.
> You are never responsible for more then your deductible!
> If you cancel in the first 60 days, it is 100% refundable, after the 60
> days, it costs $50 and the plan will be pro-rated!
> To transfer the contract it costs $40!
> The warranties I sell are geuine VW warranties. I DO NOT deal in
> aftermarket
> warranty companies! The service contract is backed by VW and fascilitated
> thru Fidelity Warranty Services!
> Here are the coverages:
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> The Gold Plus covers all of Gold plus:
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> The Platinum covers all that and the rest of the entire car w/ the
> exception
> of this:
> brake linings,brake drums and rotors,disc brake pads,std trans clutch
> components,air bags,solar powered devices,hinges, glass, lenses,sealed
> beams,trim moldings,door handles, lock cylinders,tires, batteries, light
> bulbs,upholstery, paint,bright metal,freeze plugs,heater and radiator
> hoses,exhaust systems,shock absorbers,audio,security or other systems not
> factory installed, work such as front end alignment or wheel balancing,
> constant velocity joint boots, safety restraint systems,cellular
> phones,electronis transmitting devices{except those specifically listed
> under silver, gold, or gold plus coverage},radar detectors,appliances,near
> object avoidance systemand all oither laser radar cruise control
> components,
> vinyl and convertible tops.
Here are the quotes depending on how many miles are on your Touareg
Please note that this contract starts from the day you sign up and the
miles
are on top of what you allready havexxxx +
These quotes are vaild until you hit 9999 miles or the end of the year!
4yrs or 100K=$1537
5yrs or 60K=$1142
5yrs or 75K=$1296
5yrs or 100K=$1588
6yrs or 60K=$1220
6yrs or 72K=$1353
6yrs or 85K=$1539
6yrs or 100K=$1741
7yrs or 70K=$1456
7yrs or 100K=$1829
10yrs or 10K=$2148
These quotes are valid up to 24999 miles{note, you get an additional 15K, however, the price jumps dramatically!}
4yrs or 100K=$2092
5yrs or 60K=$1870
5yrs or 75K=$2049
5yrs or 100K=$2178
6yrs or 60K=$1968
6yrs or 72K=$1990
6yrs or 85K=$2398
6yrs or 100K=$2693
7yrs or 100K=$3177
These quotes valid up to 34999 miles
3yrs or 36K=$1771
4yrs or 48K=$2056
4yrs or 60K=$2170
5yrs or 60K=$2302
5yrs or 75K=$2591
6yrs or 60K=$2397
6yrs or 72K=$2571
These quotes valid up to 44999 miles
3yrs or 36K=$1972
4yrs or 48K=$2398
4yrs or 60K=$2550
5yrs or 60K=$2759
6yrs or 60K=$2932
6yrs or 72K=$3398
__________________
__________________
Chris Farnham
Main: 609-386-0084
Direct: 609-589-2450
Cell: 609-850-0244
Email: [email protected]
Burlington VW
4500 Rt130 South
Burlington, NJ 08016
http://www.burlingtonvw.com
Hi Chris,
Is see these prices are for 2011-2015 Touaregs. What would be the price for a 6/60 platinum warranty with a $100 deductible on a 2008 Touareg with less than 34999 miles? It is currently covered by your platinum plan but I was hoping to extend it before it reaches 35,000 miles.
Hi Chris,
It would be a few more bucks then the 2011 and so on due to the fact that the 2011 thru 2015's have the 10 years or 100K Powertrain Plans already from the factory to lessen the burden
Here are your quotes
Platinum Plan
Std $100 deductible
Under 34999 miles 2008
3yrs or 36K=$1875
4yrs or 48K=$2198
4yrs or 60K=$2327
5yrs or 60K=$2487
5yrs or 75K=$2793
6yrs or 60K=$2567
6yrs or 72K=$2762
PM sent
Chris,
When you say, for instance, 5 years or 75k, does that coverage extend to 75k miles, or your current mileage +75k?
Chris,
what if i have already purhcased the extended warranty when i purchased my cpo car in 2013. Will this extend the extended warranty i already own?
I have a question. My 2011 TDI was under cpo waranty. I had two failures of the adblue system. One reluctant pump and one Nox sensor/control unit. The second failure was covered under cpo but I had to call V of A to get this accomplished. The question is with the Platinum coverage is the adblue system covered. The dealer initially tried to say the adblue was part of the exhaust system (which of course it is not) when I had the Nox sensor go out and was not going to cover the repair. The Platinum plan excludes exhaust systems so I just want to make sure the adblue system is covered before I purchase for my new 2014 TDI.
Discussion Starter #9
From wasp hat I have been told, the ad blue system is not a covered item on the VW Drive Easy coverages.
Discussion Starter #11
Here is the latest word from VW
The AdBlue pump is a covered item as well as the DPF filter{using a factory air filter} under the 8yrs or 80K Federal Emissions Act.
Chris
Discussion Starter #15
Just received word from VW and warranty company dividion that the 2004 models and below will no longer be availale for coverage, no matter the miles.
I tried inpliimenting it into the system to get a quote and found this out today 01/10/2010
Chris
What do you think about "Care Plus," which I understand involves prepaying VW for your service for up to 4 or 5 years, depending on the model? Does it save any money?
Also, I imagine one could save on paying tax by buying it out of state and then using the safe harbor provisions (paying a fixed tax on transactions under $1,000) on the state tax return.
Discussion Starter #19
I looked into this about 6 years ago and I deemd it not a very good deal for my clients. It was just not that favorable to them as it did not cover all the servicing that he manufacturer suggests to be performed and thus more money out of pocket!
It may have changed now, however, now I am under the understanding that only the selling dealer is eligible to sell the prioduct at point of sale
I am sorry I cannot help on this one!
Chris
Thanks for answering my question. I guess I'll just stick with the standard 2 years that comes with the car and then pay for servicing out of pocket after that.
1 - 20 of 61 Posts
About this Discussion
20 Participants
philthyphil
Club Touareg Forum
Full Forum Listing
