1 - 10 of 10 Posts
Hi guys,
I am posting here because there is a buzz sound when I go over 50kmph and I think it is coming from the right small speaker (next to the interior door handle) in the right front door.
You can hear it only if you sit in the front passenger's place. I checked the mirror and the door interior for any vibrations or loose plastic without success. Is the same with the stereo system on and off.
The car is a 2008 v6 tdi full option.
Did you heard about something like this ?
Thank you in advance,
Stefan
Speed warning?
Probably not coming from the speaker itself. Try driving with your mirror folded in and see if the noise goes away.
Discussion Starter · #4 ·
The speed warning is off and the mirror has no loose parts at least on the outside. But is a good start, thanks.
take the speaker out, look and re-fit
Discussion Starter · #10 ·
So I finally got the hang of it. I taped the hinge of the mirror and the buzz was gone. With the mirrors folded I noticed that piece of black plastic thing which is supposed to be like a rim or something like a seal ...
I added some silicon between it and the mirror and no problem since then.
The buzz over 60km/h was freaking annoying so I hope this will help someone on the future.
1 - 10 of 10 Posts
