1 - 3 of 3 Posts
Doing some work and noticed this vacuum line off the tandem pump had a missing nipple. Not sure what it went to??
The red RTV is from a previous owner.
That nipple on my R5 feeds the vacuum o the vacuum reservoir behind left headlight & the solenoid valves that feed the EGR, ASV and VGT actuators.
If you have had that vacuum leak for a while you would have pulled dust into the tandem pump.
Replace the tandem pump, as a failed tandem pump can pump diesel into the sump. Which means blown or runaway engine.
Turns out the student working with me broke it off when removing the fuel line off the right tandem pump. So it just happened yesterday w/ no time running with it broken (right tandem pump is already new btw)
I replaced the fuel lines as they were all dry cracked and while I was there -might as well. The return lines had to be sliced off the fuel rail hence the large split in the line in the center of the picture.
I plugged the hole as well as the smaller line above it that it fed.
I did an EGR delete on the V10 and this feed was no longer required.
NO MIL, no pending codes.
1 - 3 of 3 Posts
