Hi All
I would appreciate if someone can let me know what size brake pads fit my 2015 V8 TDi R-Line I find all sizes (300mm 330mm etc)
Also a recommendation on which brand you found to be good (Bosch, Bendix, DBQ??)
I need to fit front and rear pads, rotors and sensors.
Much appreciated
Have a look at this from Brembo
http://www.bremboparts.com/asiapacific/zh/catalogue/vw-touareg-7p5-4-2-v8-tdi/000033308-1
I expect your's has 360 fronts and 330 rear but check the PR codes in the boot of your vehicle for the brake codes and match them up to the codes in the table to be sure. Lots of discussions over what works best but I like the Brembo even tough the pads are usually Pagid rebranded as Brembo since Brembo doesn't do friction materials yet. Zoomzoom autoparts in Vic seems to do a good price in Oz or you can try overseas - buycarparts.co.uk for example. John
· Premium Member
Had the rotors, pads and sensors replaced yesterday. V10 has done 180 000km. VW had wanted to replace them at 40 000km!
Reactions: Singh
· Learner
Hi All
Much appreciated
G'day,
Thats a good question, would be good to look into this and see what fits. I have the same Touareg as you and at some point will have to replace the rotors and pads.
Will check with a local supplier here in Sydney and see what they have to say.
· Learner
G'day Wannabe!
Good to hear from you. 180,000kms! that must be a record for the Touareg. Must be your unique driving style and long range driving perhaps.
Maybe you should start a Poll thread to see who lasted the longest on their original pads/rotors!
