My '05 3.2L Treg's boot will not open. Neither the glass or the tailgate. It will "pop" and the bottom metal bracket does work but nothing in the door does so it will not fully latch open or close without using the manual release. It will latch shut if I use the hatch button to get the bottom part to move out, then use manual release in the hatch. I have checked and repaired all the B-pillar wiring, I actually took the carpet out and repaired all the wiring front to back due to water ingress from the firewall (there was alot). I also checked the wiring in the hatch itself behind the panel and near the struts for the hatch. I have tried a new actuator in the hatch. The only other thing I can think off is maybe water was in the roof liner in the trunk and caused corrosion there? where is the control module in the boot so I can trace the wire from there maybe?
Here are the codes for the electrics:
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0101599
Shop #: WSC 31414 000 00000
VCID: 46D5454FF4BDC21B91E-5160
1 Fault Found:
00907 - Intervention load Management
000 - -
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0C Airbag 8.4E+ H10 0952
Coding: 0012355
VCID: 2517E2C329FB2903B84-5160
No fault code found.
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000231
VCID: 41DF5653DD93E523A4C-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 870 T
Component: KOMBIINSTRUMENT RB8 2010
Coding: 0007331
VCID: 47CB484BF3B7DB136A8-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9C397A6B93CAB1B2-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Shop #: WSC 00000 000 00000
VCID: 45D74243C9BBC903984-5160
Address 22: AWD Labels: None
Part No: 0AD 927 755 AJ
Component: TRANSFERCASE 0100
VCID: 03539C5B870F3733F60-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000001
VCID: 6695A5CF947DE21B71E-5184
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77ABF88BC3D76B93DA8-5160
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000002
VCID: 678BA8CB9377FB134A8-5160
1 Fault Found:
00774 - Level Control System Sensor; Rear Left (G76)
008 - Implausible Signal - MIL ON
Part No: 7L0 959 933 E
Component: H4 HSG 0200
Coding: 0000085
VCID: 3E252DAFAC6D9ADBD9E-4B3C
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
2 Faults Found:
00926 - Terminal 30
011 - Open Circuit
01134 - Alarm Horn (H12)
000 - -
Address 47: Sound System Labels:
VCID: 55F792033C0B7983E84-5160
Note: Excessive Comm Errors
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180
Component: Radio DE2 0009
Coding: 0001035
VCID: 6A8DD1FF8065C67B556-5160
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000855
Shop #: WSC 31414 000 376832
VCID: 3C2127A7BA7188CBF7A-5160
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 E HW: 7L0 907 383 E
Component: ANHAENGERELEKTRONIK 8254
Coding: 0000002
Shop #: WSC 93022 999 52576
VCID: 3635358F845D529B01E-5160
End----------(Elapsed Time: 08:29, VBatt start/end: 14.0V/14.0V)-----------
Component: 3001
Coding: 0101599
1 Fault Found:
000 - -
Coding: 0012355
Coding: 0000231
Coding: 0007331
Coding: 0000006
Coding: 0000001
1 Fault Found:
Coding: 0000002
1 Fault Found:
Coding: 0000085
2 Faults Found:
00926 - Terminal 30
011 - Open Circuit
000 - -
Coding: 0001035
Coding: 0000855
Coding: 00217125
Shop #: WSC 31414
Coding: 0000002
