1 - 1 of 1 Posts
Hi everyone. I have a VW Touareg 7P 2012 with the RCD550 Radio with the Infotainment Gateway 7P6907540B company installed. I got the 7P6035730N BLUETOOTH MODULE and the Wiring.
I connected all wiring and the bluetooth module. I logged into VCDS and selected 19 CAN GATEWAY. Selected 77 Telephone in the 19 CAN GATEWAY. Now the Telephone is not showing on the VCDS. 77 Telephone is saying "CANNOT BE REACHED" in the VCDS Auto Scan. Please see the AUTO SCAN REPORT below and help. Do i need to change the 56 RADIO coding or the A7 INFOTAINMENT GATEWAY coding.
233587
233586
Tuesday,08,October,2019,20:50:06:39744
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVGZZZ7PZDD021880 License Plate:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 2E 34 36 42 46 52 53 55
56 62 72 77 A7
VIN: WVGZZZ7PZDD021880 Mileage: 83278km-51746miles
06-Seat Mem. Pass -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Cannot be reached 0100
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 0100
77-Telephone -- Status: Cannot be reached 0100
A7-Infotain. Interface -- Status: OK 0000
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 H HW: 4G0 907 401
Component: 3.0TDI EDC17 H39 0004
Revision: 53H39---
Coding: 292A0012232E00000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM3T0DI0117P0907401H 001004
ROD: N/A
VCID: 3460C7929FA02FEF73-8060
No ASAM data for: "EV_ECM3T0DI0117P0907401H" (VW52)
5 Faults Found
14581 - ROD - Unknown Error Code
- 00 [109]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 81923 km
Date: 2019.08.15
Time: 11:26:37
5604 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
17403 - ROD - Unknown Error Code
- 00 [032]
10585 - ROD - Unknown Error Code
- 00 [032]
10586 - ROD - Unknown Error Code
- 00 [032]
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: None
Part No SW: 0C8 927 750 BK HW: 0C8 927 750 BK
Component: AL1000 AISIN 001 2268
Serial number:
Coding: 001168
Shop #: WSC 50305 001 1048576
ASAM Dataset: EV_TCMAL919031 002114
ROD: N/A
VCID: 76E43D9AC95C7DFF8D-8022
No ASAM data for: "EV_TCMAL919031" (VW52)
No fault code found.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 427720010EC815
Coding: 5B6B13C30B262554DAFCC89BD0D2A440F700
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4A9CB96AED24491F39-801E
Part No SW: 4H0 907 064 CK HW: 4H0 907 064 CK
Component: BCM2 2.0 H32 0421
Revision: 00002001
Coding: 09960010000000000000
VCID: 74E00792D7206FEFB3-8020
Subsystem 1 - Part No SW: 7P6 959 754 N HW: 7P6 959 754 N
Component: FBSTOUAREGIDG H04 0051
Serial number: 0510000039290013
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 2312000165331016
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000041633607
Coding: 0038330000004201000001010101202020202121202020
VCID: 3460C79297A02FEF73-8060
1 Fault Found
03333 - Motor for Cushion Angle Adjustment
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 54
Mileage: 82406 km
Time Indication: 0
Date: 2019.08.27
Time: 17:18:25
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28231229606624
Coding: 108501
ASAM Dataset: EV_VW526AprkiAssis2 001012
ROD: N/A
VCID: 4382944ECA0E9857FA-8016
No ASAM data for: "EV_VW526AprkiAssis2" (VW52)
Address 15: Airbags (J234) Labels:. 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag00K H05 0025
Revision: -------- Serial number: 003L0005F0MN
Coding: 00000000000000000000000000000000304B
ASAM Dataset: EV_AirbvAW10BPAVW526 001001
ROD: N/A
VCID: 418E9E46D0128A47E8-8014
Subsystem 1 - Serial number: 3575LRB405R1KR0EH0U9
Subsystem 2 - Serial number: 3585LRB405V1KR0EA9OA
Subsystem 3 - Serial number: 3515RRB404T1MFU42OSR
Subsystem 4 - Serial number: 3525RRB404R1MFU4CPOX
Subsystem 5 - Serial number: 3555NRB40024UO12M9V-
Subsystem 6 - Serial number: 3565NRB40044UO128HNP
No ASAM data for: "EV_AirbvAW10BPAVW526" (VW52)
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LJJ0000S
Coding: 000C35
VCID: 3878F3A28BC8CB8F5F-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0215593
1 Fault Found
00886 - Turn Signal Switch (E2)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 47
Reset counter: 60
Mileage: 80382 km
Time Indication: 0
Date: 2019.06.26
Time: 11:04:46
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 881 G HW: 7P6 920 881 G
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658221012592025
Coding: 333731003A00000800000A
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526.rod
VCID: 40889B42DB18834FE7-8014
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7P6 907 530 E HW: 7P6 907 530 E
Component: Gateway-CAN-L H10 6028
Revision: -------- Serial number: 00000000727713
Coding: 000103AD00
ASAM Dataset: EV_GtaewVW526UDS 001007
ROD: N/A
VCID: 3A7CE9AABDC4D99FA9-806E
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650483714
No ASAM data for: "EV_GtaewVW526UDS" (VW52)
1 Fault Found
5733 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 83278 km
Date: 2019.10.09
Time: 09:00:40
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 7P6 035 342 D HW: 7P6 035 342 D
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663243743
Coding: 010100
VCID: 326CC18A6DB421DF61-8066
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 N HW: 7P0 907 553 N
Component: PASM H01 1550
Revision: 00000000 Serial number: 00000122340093
Coding: 14210000
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 428C914AD514915FF1-8016
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000041045652
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 52
Mileage: 82223 km
Time Indication: 0
Date: 2019.08.18
Time: 14:37:19
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. (J393) Labels: Redir Fail!
Revision: 00002001 Serial number: 0185196725
Coding: 0100162028B9009483200620000000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO1850620$
Coding: 191100
Subsystem 2 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO18476909
Coding: 191100
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake (J540-) Labels:. 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C12A1700590
Coding: 01040100
ASAM Dataset: EV_AprkbA7 000006
ROD: N/A
VCID: 3664FD9A89DC3DFF4D-8062
No ASAM data for: "EV_AprkbA7" (VW52)
1 Fault Found
0052 - ROD - Unknown Error Code
- 00 [008]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 212
Reset counter: 1
Mileage: 834048 km
Date: 2052.03.27
Time: 13:49:03
Address 55: Headlight Range (J745) Labels: None
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: --------------
Coding: 012E00000F000200
ASAM Dataset: EV_HeadrLegulVWAFS 005006
ROD: N/A
VCID: 7CF02FB2F77027AFFB-8028
No ASAM data for: "EV_HeadrLegulVWAFS" (VW52)
1 Fault Found
5275648 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 82733 km
Date: 2019.09.20
Time: 18:18:16
Address 56: Radio (J503) Labels: None
Part No SW: 7P6 035 195 B HW: 7P6 035 195
Component: RCD550 210 0317
Revision: AA001001 Serial number: VWZ8Z3MB1003YE
Coding: 0100042004000000B0FC1D1200
VCID: 3664FD9A81DC3DFF4D-8062
1 Fault Found
00468 - CD-ROM Drive (R92)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00111110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 176
Mileage: 77075 km
Time Indication: 0
Date: 2019.03.13
Time: 09:38:51
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right (J389) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000131470229
Coding: 011C04200001251005080000
VCID: 3A7CE9AAB5C4D99FA9-806E
Address 77: Telephone
Cannot be reached
Address A7: Infotain. Interface (J885) Labels: None
Part No SW: 7P6 907 540 B HW: 1K0 907 951
Component: IF CAN Infot. H29 0013
Serial number: 111012F2001492
Coding: 0405260200000000100B
ASAM Dataset: EV_InfotInterCotni 001002
ROD: N/A
VCID: 3878F3A283C8CB8F5F-806C
No ASAM data for: "EV_InfotInterCotni" (VW52)
End-------------------------(Elapsed Time: 03:54)--------------------------
1 - 1 of 1 Posts
