Blower wasn't working, I noticed that I had heat, and AC compressor engaged , but no blower . VCDS said blower buttons were working . Bunch of other errors , that I did not even worry about ,
So I removed the motor following this video and cleaned that sucker real well w a can of compressed air , hand brush , and electronics spray cleaner ...
Removed the terminals from the resistor , and applied 12v current w 2 wires from battery directly to the motor , and noticed that the motor was working real well.
Since I saw so many reports of blower problem and resistor , I bought one from Amazon for 30 bucks .
I had checked the refrigerant pressure , and noticed I had no warnings, even though can't find the refrigerant pressure anywhere .. 🙄🤦maybe I am not looking into the manual properly, which is a great possibility 😂.. latter will look into that again..
Could not find resistance values as usual , either for the resistor pins , or blower motor , I just noticed they were different, when the new resistor arrived as noted in the pictures .. the resistor installed in the motor is the new one, outside the old one, btw. I have no idea what those numbers mean, just noticed they were different.
- That indicates that the resistor was indeed the culprit , and all is now working as it should ,& will have to check the refrigerant latter.
Btw: the brushes on the motor still had a lot left to go, so I did not need to replace them, and add new ones ..
This motor was really dirty .. when I sprayed compressed air before I sprayed the electronics spray cleaner, there was a lot of black dust coming out.
Just having lots of fun friends, while saving money , and at least this time , it wasn't that complicated .
