Two things
1 anyone got pics with larger tires?
2nd we should get a list of rims and tires sizes that fit
George
George
What logic was used in deciding to place spacers? If you have someone turn the wheels while you watch the orrientation inside the wheel well, and how clearances change, you will see clearly that spacers actually increase the arc range which comes close to the liner.I don't get it Mike, my 265/65/18's rub like crazy and I used spacers and also cut away the plastic around the IC'sMaybe if I pulled the spacers out??
275/65/18 really fills up the wheel well. I can't imagine any thing larger without spacers. I'm liking the Hankook ATM all terrain tire for $140 down here. I can imagine what they are up there. I got a burger and fries at Burger King in Dutch Harbor and didn't get much change back from my $20.
Diameter is only an inch over stock. Your issue may be with the width and possible rubbing. Could need some spacers, but I don't know for sure.Any one fit these on a 2008 Treg V6 Gas?
I think this in a Brigestone Dueler H/L Alenza would be the best bang for your buck? If it fits that is.
