Looks like a well done conversion. Whats the diameter of your rim and how's the clearance And assuming you kept the same master cylinder, do you notice a difference in pedal travel
The rims are 20 inches. The clearance is tight, around 5-7mm, but i know for sure that using stock wheels clearance is not an issue. Pedal is still "soft", i think i may have some air trapped and i will adress that issue soon.Looks like a well done conversion. Whats the diameter of your rim and how's the clearance And assuming you kept the same master cylinder, do you notice a difference in pedal travel
Thanks for the ideea, now i'm planning to upgrade them with HEL VW-4-460. I've heard stainless steel hoses makes a big difference.Have you uprated the brake hoses?
If not, you should.
"Legit?" The 18z's were fitted to the V10. And no, no need to re-code.Over here, I am cheaping out on buying legit OEM replacements.... you guys are just throwing your money away on "upgrades"...... maybe I need to immigrate "back".![]()
Hmmmm. Too bad you weren't in the room with the Porsche/VW engineers when they were designing the braking system for the Touareg and Cayenne. "Hey guys, we don't need those fancy 6pot calipers and larger rotors. It's all for show anyway. Look at this cheap crap we can buy from Canada. Think of all the money we'll save!"Yes, I run el cheapo parts.... not even OEM... this is CAD
.... and you guys don't have V10s so I'm not sure why you're mentioning that..... are you suggesting the V10s could outbrake the rest of us?![]()
But the improved performance!!!!!!!!……Too bad you don't spend any time reading the many available tech, engineering, physics, economics, marketing articles that are available for free instead of choosing to be a sheep.....
Just think of the knowledge you could absorb to understand physics, heat dissipation, friction, etc....
I'll keep driving without brakes over here because I didn't spend a few $K on better parts.
That Urus is a bad mofo! And based on the same platform as the Touareg/Cayenne/Q7.For cool points, I'd do Urus brakes. Hard to beat those!
Hi @SaVAGeSoot,Over here, I am cheaping out on buying legit OEM replacements.... you guys are just throwing your money away on "upgrades"...... maybe I need to immigrate "back".![]()
