It would appear that tire selection for the VW Touareg starts off with the three doors scenario (18 in 19 in 20 in) and behind two of those doors are hungry tread eating tigers ! Past that entry point, brand and model wise ratings are mostly down hill after that. OEM tire ratings are almost all over the map. Other than OEM almost every selection good/bad is an outlier.
Having said that @ almost 20,000 miles, I am having good results with the 18 in size and GY LS 2 OEM's. The scenario is I run the so called highway fuel savings PSI ( in the oem owners manual) @ 3 PSI above. (33 psi/38 psi TO 36 psi/41 psi.) Early on in the game to 500/1000 miles, I did a very easy tires brake pads and rotors and suspension break in : NTE 65 mpg.
Wear per 1/32nd in has been 14,000 miles plus+.
