Hey there,
I know there are a lot of threads out there about battery draw issues, kessy issues, and the like, however I think my case is unique.
I have an 04 that's been pretty darn solid. Definitely had a lot of issues taken care of at the dealer under warranty early on, but for the last 5 years (it was my father's car until four years ago) has been relatively problem free. However, there is a battery draw issue of some sort that presents itself sporadically. It seems to come about when colder temps come, which is an issue for me, because that's when I need my car most.
Some background kessy info:
The touareg is a fully loaded 04. The lock button on the driver side rear door handle (outside handle) has been detached for the last few years, and so that button has not worked for a while. A bit over two years ago the lock button on the driver door stopped working. However, the doors do still sense the presence of the key and unlock when I grab the door handle (though sometimes I have to physically be holding the key, rather than having to know the key is in my pocket).
Now onto the battery draw issue
The car and battery have been great for the past 9 months. The issue I am experiencing now, I experienced a year ago as well, then I put the touareg on a trickle charger and it's been fine since.
When the issue presents itself, here is what happens. When I get in the car and turn the key, it hesitates to start, the MFD in the gauge cluster stays black (off) for about two seconds (a noticeable amount of time) after the engine is running, and then it comes on with some error lights. I believe it's usually the one that comes up when the parking lights are left on.
I have updated the nav firmware, so ruled that out as the battery draw. I know a lot of people have had to fully replace or rebuild their kessy units. Based on the way mine still semi-functions, it seems it might not need replacement? I don't really mind that the driver side lock buttons don't work, but if the door handles are the battery draw here, I want that fixed. If I do need to replace the door handles, will new ones talk to the kessy module, or will I need a whole new kessy module as well?
A possibly related issue: the car no longer recognizes when the driver's door is open, unless it's pulled shut but not "closed." If that makes any sense. This is more an annoyance than anything.
Hoping the minds of club touareg have some insight here.
Thanks so much,
Brad
Thanks so much,
Brad
