1 - 2 of 2 Posts
hi, for the last few days my touareg (2004 2.5 diesel) will not start in the morning. it seems that the battery is drained overnight (parasitic drain?). i checked all of the obvious, in- out lights,stereo, a/c..... nothing is shown on the dashboard. as soon as i charge the battery for about ten minutes the car starts. any ideea? thank you!
Most likely you either have a bad battery (need to get it tested) or if you have keyless touch entry you may have a bad kessy module.
We need the battery voltage measured right after turning off engine, battery voltage the next day right before starting engine and a vcds scan posted here to help you further.
1 - 2 of 2 Posts
