I'm new at towing. Trying to set up the Treg with the right ball mount. The 2013 Touareg manual contains spec info that isn't doable. Does anyone know if this really matters:
1. There is no ball mount on the market that meets their specs. (6 1/8" from center of ball to center of the hole for securing the pin on the ball mount.) See below. Closest I can find is 8.25 inches.
2. The manual also says not to use any thing bigger than a 2" ball. The 19-foot airstream I want to pull needs a 2 5/16" ball. All the airstreams use this size. So what happens if I use the larger ball? I know people pull airstreams with tregs.
Any thoughts much appreciated.
