1 - 1 of 1 Posts
I have been reading and searching for days with no luck. My backup camera flashes a picture for a second or two and then disappears. I took it to the stealer and they said I have two controllers and would need to change both and it would require dropping the headliner. They did an awful job on the trim they removed and I did not let them proceed. I could find nothing online about a second controller. I had someone tap the camera and the caner flashed so I changed the camera and inspected as much as I could of the harness and still have the same problem. Does anyone here have any ideas? I found a used controller with the same part number.(no letter) Does anyone think this may be the issue? Should it work without programming if I try it? The vehicle is immaculate with 120k Thanks
1 - 1 of 1 Posts
