Hi there I read through all the threads posted here but was not able to find the answer to a problem I have and need expert help. My air compressor pump is working (I rebuild the kit with solid high pressure coming out!) and this feeds into the pneumatical distribution block to the 4 outlets to the individual suspension for each wheel - yet NO air is coming out in any of the four outlets. Also no leak any where. The pump does's stop and continues building pressure. The vehicle is sitting very low. On the panel just appears CHASSIS ERROR (I have no access to VAG code) it seems that this is either a electrical problem (valves not receiving instruction to open) or the block is obstructed for all 4 outlets (?)
Please give me your advice where to check and find the remedy to this problem - THANK YOU !
