Hey SavSoot here’s another scan from just now. more details ....
Thursday,16,March,2023,20:13:40:57689
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
Mileage: 134102km-83327mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
56 5F 62 65 69 6C 6D 72 85 8B 8E
Mileage: 134102km-83327miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF82755A21130E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 95884 999 00000
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 303916C2BAAD461ABF3-8065
VINID: 9E65D48094A001650000510614AD580033
1 Fault Found:
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Engine RPM: 759.00 /min
Normed load value: 11.8 %
Vehicle speed: 0 km/h
Coolant temperature: 74 ∞C
Intake air temperature: 17 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.860 V
Unlearning counter according OBD: 32
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 55
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 100 3374
CVN: B916A756
Coding: 010200000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40D946020A0DD69A4F3-8015
1 Fault Found:
23198 - No Communications with Steering Angle Sender (G85)
U0126 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Engine RPM: 877.5 /min
Transmission input speed: 846 /min
Transmission output speed: 0 /min
Engine torque: 40 Nm
ATF temperature: 80 ∞C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: closed
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 42914438052356 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F58DAF8C89992D7F6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC16232364502FAA3B-8019
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 0D860016000000000000
VCID: 77ABEDDE1FC351223E9-8023
Subsystem 1 - Part No SW: 7P6 959 754 AR HW: 7P6 959 754 AR
Component: FBSTOUAREGIDG H08 0084
Serial number: 0514000127033013
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3214000178740010
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: B686000A80
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 78A9EEE2125D5E5A373-802D
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00000981971801
Coding: 26000096D63C5D010020480780005D4C431C6608A2014261800000008040110000000000000000
VCID: 6A8DC4AA5C71FCCAB17-803F
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 141213 033 0021
Serial number: 90243400150108224357
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20472526
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000001401150043
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01D5F27B
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA109402000010548994
Coding: 010300
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231500902150
Coding: 518D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D14A121E15CABA6BB-8011
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Serial number: 00000000000000
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C2132F266E5B27A13B-8069
4 Faults Found:
10240 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
[FAULT_BLR_BLK8_31]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 12
Mileage: 133773 km
Date: 2023.02.25
Time: 17:37:48
Control Module temperature: -4 ∞C
Voltage terminal 15: 13.926 V
Velocity_vehicle_reference: 16.43 m/s
Longitudinal_acceleration_vehicle_reference: 0.15 m/s≤
11264 - Sensor for Automatic Distance Regulation
C110B 49 [008] - Internal Electronic Failure
[FAULT_UAR_NVK8_31]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 23
Mileage: 133942 km
Date: 2023.03.09
Time: 17:51:34
Control Module temperature: 5 ∞C
Voltage terminal 15: 13.194 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
32512 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_LWI]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Control Module temperature: 9 ∞C
Voltage terminal 15: 11.948 V
Velocity_vehicle_reference: 0.00 m/s
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 150
Reset counter: 246
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:37
Control Module temperature: -2 ∞C
Voltage terminal 15: 13.173 V
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag04T H10 0043
Revision: -------- Serial number: 003NK00276U5 Dataset Number: 7P6003V____ 1643
Coding: 000000000000000000000000000000003454
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43D3490E1B1BCD82521-8017
Seat occupied recognition:
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R14A220KYGA
Crash sensor for side airbag: driver side:
Serial number: 3575LRB405J20N9298I6
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB404R2UUQ2A0BB
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB404T30TVQ8PHP
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB404T30TVQB9D9
Crash sensor for front airbag: driver side:
Serial number: 3557BRB401E52O771CBS
Crash sensor for front airbag: front passenger side:
Serial number: 3567BRB401G52O76OJDJ
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OAB000A1
Coding: 000CFD
VCID: 3D273FF67D7FBB72245-8069
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0075660 TRW 20141210
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 883 H HW: 7P6 920 883 H
Component: Kombi H13 0515
Revision: 13240300 Serial number: 658090115592029
Coding: 0B1733016F080008020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001691734 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB5F40655D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 32008703185701310164
2 Faults Found:
4230 - No Communications with Steering Angle Sender (G85)
U0126 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:22
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Control Module temperature: 33 ∞C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
[Powermanagement active]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 252
Mileage: 133589 km
Date: 2023.02.04
Time: 04:30:40
Voltage terminal 30: 12.3 V
Voltage terminal 15: 0.0 V
Control Module temperature: -23 ∞C
System status: Awake_Timer_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 3
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000130950737
Coding: 00581B0000004001000001010101202020202121202020
VCID: 34311AD24E357A3ADBB-8061
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0357633118 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FDB45FE77F3A962369-806B
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0357660891
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000132762880
Coding: 011D17205E00453005080001
VCID: 7AADF4EA2CD14C4A417-802F
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0357767894
Coding: 0187123A68B9509580A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 22014678
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.062 H01 0008
Serial number: WOO34338184
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.062 H01 0008
Serial number: WOO34404784
Coding: 191100
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 133895 km
Time Indication: 0
Date: 2023.03.05
Time: 15:39:25
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002235308
VCID: 75B7E7D605CF23322C5-8021
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000133183699
Coding: 011D17205E00453005080000
VCID: 48C95E2222BDEEDA873-801D
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1511400311 Dataset Number: A001
Coding: 01040200
Shop #: WSC 54572 001 1048576
ASAM Dataset: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
VCID: 363520DA58C9682AE5F-8063
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0016
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156A%0F8183369
Coding: 020007010000000001
VCID: 2411EA92FED5EABA4BB-8071
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 G HW: 7P6 035 664 A
Component: H-BN-NA H40 0881
Revision: -------- Serial number: 273L40EB004954
Coding: 020200050040E9EF79022B0E00000003F00001030000000000
VCID: 3C2132F26665B27A13B-8069
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H53 0046
Serial number: VWZ8Z9RX8002RG
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000132779704
Coding: 011C17200000253005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 H HW: 5Q0 907 273
Component: RDKBERU30 H04 0002
Serial number: 40000000007689 Dataset Number: 7P6096V____ 0026
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 41DF43060107DF9240D-8015
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0357043392 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 372B2DDE5FC39122FE9-8063
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H08 0115
Revision: 11001001 Serial number: 82330JF0199585
Coding: 0100000000010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3D273FF67DFFBB72245-8069
1 Fault Found:
13701388 - Databus
U1121 00 [008] - Missing Message
[Funktionseinschraenkung wegen fehlender Botschaft (LWI_01_alt)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:25
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 362400628 Dataset Number: 7p0771v____ 0012
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000132794892
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 392F2BE669D7875208D-806D
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007063972_3059
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A2D34EA6CD18C4A017-806F
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Control Module temperature: 8 ∞C
Voltage terminal 15: 11.921 V
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H33 0035
Serial number: 005000010801157
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
3 Faults Found:
0043 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[LWS_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Outside temperature: 8.0 ∞C
Voltage terminal 15: 11.9 V
Control Module temperature: 0.0 ∞C
0080 - Video Cable for Image Processing
C1107 02 [024] - Signal Failure
[No_connection_to_camera]
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:36
Outside temperature: -5.0 ∞C
Voltage terminal 15: 13.2 V
Control Module temperature: 4.0 ∞C
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
[No_camera_found_on_startup]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 139
Reset counter: 246
Mileage: 133615 km
Date: 2023.02.08
Time: 17:16:07
Outside temperature: 3.5 ∞C
Voltage terminal 15: 12.8 V
Control Module temperature: 2.0 ∞C
End----------(Elapsed Time: 02:22, VBatt start/end: 14.5V/14.9V)-----------
