1 - 20 of 23 Posts
2015 Touareg v6 TDI R-Line
Can someone help me figure out what is causing this fault code?
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Serial number: 00000000000000
Coding: 3701010101
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C2132F266E5B27A13B-8069
2 Faults Found:
10240 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
[FAULT_BLR_BLK8_31]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 12
Mileage: 133773 km
Date: 2023.02.25
Time: 17:37:48
Control Module temperature: -4 ∞C
Voltage terminal 15: 13.926 V
Velocity_vehicle_reference: 16.43 m/s
Longitudinal_acceleration_vehicle_reference: 0.15 m/s≤
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 93
Reset counter: 234
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:37
Control Module temperature: -2 ∞C
Voltage terminal 15: 13.173 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
2013 7P Touareg R line V8 4.2 TDI
The limited visibility fault is normally casued poor weather / snow etc blocking the camera vision in which case it should reset itself once the weather conditions improve. it can also be due to camera or radar misalignment i beleive. However you have the earlier fault saying function restriction due to faults in other modules , what are these faults ? If you have air suspension with a fault affecting the vehicle stance this can cause the ACC to shutdown and also cause misalignment in the camera and radar
do you think it’s possible it just didn’t reset itself for some reason? Would clearing the code resolve?
Clear all the codes and see what comes back is always the first step in troubleshooting ACC and emrgency braking disabled fault normally comes up on the dash within a minute of starting the car in my experience at least if still present due to faulty camera or cable
'14 TDI Execline
You can't troubleshoot when you ignore all the missing information from the "not shown" autoscan...... especially when you're the one asking for help..... provide info and keep chasing your tail.
Even the code tells you that it's due to things that we can't see.
Discussion Starter · #6 ·
Here is the full scan:
Sunday,05,March,2023,13:26:51:57689
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
Mileage: 133871km-83183mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
56 5F 62 65 69 6C 6D 72 85 8B 8E
Mileage: 133871km-83183miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
47-Sound System -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF82755A21130E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 95884 999 00000
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 303916C2BAAD461ABF3-8065
VINID: 9E65D48094A001650000510614AD580033
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 100 3374
CVN: B916A756
Coding: 010200000C008400000000000000000000000000
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40D946020A0DD69A4F3-8015
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 42914438052356 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F58DAF8C89992D7F6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC16232364502FAA3B-8019
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 0D860016000000000000
VCID: 77ABEDDE1FC351223E9-8023
Subsystem 1 - Part No SW: 7P6 959 754 AR HW: 7P6 959 754 AR
Component: FBSTOUAREGIDG H08 0084
Serial number: 0514000127033013
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3214000178740010
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: B686000A80
VCID: 78A9EEE2125D5E5A373-802D
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00000981971801
Coding: 26000096D63C5D010020480780005D4C431C6608A2014261800000008040110000000000000000
VCID: 6A8DC4AA5C71FCCAB17-803F
Component: WWS 141213 033 0021
Serial number: 90243400150108224357
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20472526
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000001401150043
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01D5F27B
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA109402000010548994
Coding: 010300
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231500902150
Coding: 518D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D14A121E15CABA6BB-8011
Coding: 3701010101
2 Faults Found:
[FAULT_BLR_BLK8_31]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 12
Mileage: 133773 km
Date: 2023.02.25
Time: 17:37:48
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 93
Reset counter: 234
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:37
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag04T H10 0043
Revision: -------- Serial number: 003NK00276U5 Dataset Number: 7P6003V____ 1643
Coding: 000000000000000000000000000000003454
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43D3490E1B1BCD82521-8017
Seat occupied recognition:
Serial number: 5850000R14A220KYGA
Serial number: 3575LRB405J20N9298I6
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB404R2UUQ2A0BB
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB404T30TVQ8PHP
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB404T30TVQB9D9
Serial number: 3557BRB401E52O771CBS
Serial number: 3567BRB401G52O76OJDJ
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OAB000A1
Coding: 000CFD
VCID: 3D273FF67D7FBB72245-8069
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0075660 TRW 20141210
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 883 H HW: 7P6 920 883 H
Component: Kombi H13 0515
Revision: 13240300 Serial number: 658090115592029
Coding: 0B1733016F080008020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001691734 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB5F40655D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 32008703185701310164
1 Fault Found:
12291 - Energy Management Active
U140B 00 [008] - -
[Powermanagement active]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 252
Mileage: 133589 km
Date: 2023.02.04
Time: 04:30:40
Voltage terminal 30: 12.3 V
Voltage terminal 15: 0.0 V
Control Module temperature: -23 ∞C
System status: Awake_Timer_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 3
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000130950737
Coding: 00581B0000004001000001010101202020202121202020
VCID: 34311AD24E357A3ADBB-8061
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0357633118 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FDB45FE77F3A962369-806B
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0357660891
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000132762880
Coding: 011D17205E00453005080001
VCID: 7AADF4EA2CD14C4A417-802F
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0357767894
Coding: 0187123A68B9509580A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 22014678
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.062 H01 0008
Serial number: WOO34338184
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.062 H01 0008
Serial number: WOO34404784
Coding: 191100
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811002235308
VCID: 75B7E7D605CF23322C5-8021
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000133183699
Coding: 011D17205E00453005080000
VCID: 48C95E2222BDEEDA873-801D
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1511400311 Dataset Number: A001
Coding: 01040200
Shop #: WSC 54572 001 1048576
ROD: EV_ParkbA7.rod
VCID: 363520DA58C9682AE5F-8063
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0016
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156A%0F8183369
Coding: 020007010000000001
VCID: 2411EA92FED5EABA4BB-8071
Part No SW: 7P6 035 664 G HW: 7P6 035 664 A
Component: H-BN-NA H40 0881
Revision: -------- Serial number: 273L40EB004954
Coding: 020200050040E9EF79022B0E00000003F00001030000000000
VCID: 3C2132F26665B27A13B-8069
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H53 0046
Serial number: VWZ8Z9RX8002RG
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000132779704
Coding: 011C17200000253005080000
Part No SW: 7P6 907 273 H HW: 5Q0 907 273
Component: RDKBERU30 H04 0002
Serial number: 40000000007689 Dataset Number: 7P6096V____ 0026
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 41DF43060107DF9240D-8015
1 Fault Found:
8402177 - System Switched Off
C106D 00 [009] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 233
Mileage: 133868 km
Date: 2023.03.04
Time: 17:27:16
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0357043392 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 372B2DDE5FC39122FE9-8063
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H08 0115
Revision: 11001001 Serial number: 82330JF0199585
Coding: 0100000000010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3D273FF67DFFBB72245-8069
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 362400628 Dataset Number: 7p0771v____ 0012
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000132794892
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 392F2BE669D7875208D-806D
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007063972_3059
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A2D34EA6CD18C4A017-806F
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H33 0035
Serial number: 005000010801157
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
2 Faults Found:
0080 - Video Cable for Image Processing
C1107 02 [024] - Signal Failure
[No_connection_to_camera]
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:36
Outside temperature: -5.0 ∞C
Voltage terminal 15: 13.2 V
Control Module temperature: 4.0 ∞C
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
[No_camera_found_on_startup]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 85
Reset counter: 234
Mileage: 133615 km
Date: 2023.02.08
Time: 17:16:07
Outside temperature: 3.5 ∞C
Voltage terminal 15: 12.8 V
Control Module temperature: 2.0 ∞C
End----------(Elapsed Time: 02:23, VBatt start/end: 14.0V/14.8V)-----------
Discussion Starter · #7 ·
I see an image processing fault code. I wonder if the water drain plug holes are clogged from over time of dirt, leaf, debris and someone the cord from the window camera to the image processing module got wet and corroded. that’s my best guess. Anyone else have any other thoughts?
Discussion Starter · #10 ·
You might want to start looking into that dying battery thing.....
Yes I will that battery is about 4 years old now. It almost died after a full day or -45 degrees Celsius weather. do you think that could be all which is causing the image processing issue? I still haven’t cleared the code yet. I will try that later today also and see if it comes back on.
'14 TDI Execline
No idea, and it really doesn't matter as if the vehicle doesn't start, you don't need any image processing for driver assist systems because..... that's right... you're not driving.
Discussion Starter · #13 ·
Hey SavSoot here’s another scan from just now. more details ....
Thursday,16,March,2023,20:13:40:57689
www.Ross-Tech.com
Mileage: 134102km-83327mi Repair Order:
Mileage: 134102km-83327miles
02-Auto Trans -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
1 Fault Found:
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Engine RPM: 759.00 /min
Normed load value: 11.8 %
Vehicle speed: 0 km/h
Coolant temperature: 74 ∞C
Intake air temperature: 17 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.860 V
Unlearning counter according OBD: 32
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 55
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
CVN: B916A756
1 Fault Found:
23198 - No Communications with Steering Angle Sender (G85)
U0126 00 [040] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 235
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Engine RPM: 877.5 /min
Transmission input speed: 846 /min
Transmission output speed: 0 /min
Engine torque: 40 Nm
ATF temperature: 80 ∞C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: closed
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
Revision: 00002001
Coding: B686000A80
Coding: 004DBD
Coding: 025223
Coding: 010300
Coding: 518D04
Coding: 3701010101
4 Faults Found:
[FAULT_BLR_BLK8_31]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 12
Mileage: 133773 km
Date: 2023.02.25
Time: 17:37:48
11264 - Sensor for Automatic Distance Regulation
C110B 49 [008] - Internal Electronic Failure
[FAULT_UAR_NVK8_31]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 23
Mileage: 133942 km
Date: 2023.03.09
Time: 17:51:34
Control Module temperature: 5 ∞C
Voltage terminal 15: 13.194 V
32512 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_LWI]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Control Module temperature: 9 ∞C
Voltage terminal 15: 11.948 V
Velocity_vehicle_reference: 0.00 m/s
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 150
Reset counter: 246
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:37
Coding: 000CFD
Coding: 000103AD00
2 Faults Found:
4230 - No Communications with Steering Angle Sender (G85)
U0126 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:22
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Control Module temperature: 33 ∞C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 252
Mileage: 133589 km
Date: 2023.02.04
Time: 04:30:40
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 3
Coding: 030221
Coding: 030221
Coding: 191100
Coding: 191100
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 133895 km
Time Indication: 0
Date: 2023.03.05
Time: 15:39:25
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Coding: B00000
Coding: B00000
1 Fault Found:
13701388 - Databus
U1121 00 [008] - Missing Message
[Funktionseinschraenkung wegen fehlender Botschaft (LWI_01_alt)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:25
Terminal 15 status: Terminal 15 on
Coding: 0533314003
Coding: 69020000
Slave 1:
Coding: 3701010101
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Control Module temperature: 8 ∞C
Voltage terminal 15: 11.921 V
ROD: EV_BTR_002.rod
3 Faults Found:
0043 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[LWS_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 23
Mileage: 133895 km
Date: 2023.03.05
Time: 15:39:23
Outside temperature: 8.0 ∞C
Voltage terminal 15: 11.9 V
Control Module temperature: 0.0 ∞C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 139
Reset counter: 246
Mileage: 133615 km
Date: 2023.02.08
Time: 17:16:07
End----------(Elapsed Time: 02:22, VBatt start/end: 14.5V/14.9V)-----------
'14 TDI Execline
Issues from what I can see:
  • you don't understand what you're looking at
  • you aren't following instructions
  • the information you're providing is junk
2 Faults Found:
[FAULT_BLR_BLK8_31]
Freeze Frame:
Fault Frequency: 2
Mileage: 133773 km
Date: 2023.02.25
Time: 17:37:48
U1113 00 [009] - -
Freeze Frame:
Fault Frequency: 93
Mileage: 133614 km
Date: 2023.02.07
Time: 21:06:37
Focus on the RED text.
Which one of these points in time would you like to take into consideration? Because they are all different!
Focus on the BLUE text.
Which of these odo readings would you like to discuss? Yup... they are also all different!
Focus on the GREEN text.
These are the number of times those faults have happened, with the initial fault being at the date & odo shown by the RED and BLUE text.
So, if you're still with me, unless you follow the instructions given to you several times above already and clear the codes to do a fresh scan in order to see what codes are current, you can start loading up the parts cannon.
Your move.
Discussion Starter · #16 ·
Your move.
Yes I hear what you’re saying. And I have cleared the codes last night and will scan again later today when i have a second.
This may be a novice question: but, I was hoping the codes for the ACC were not that big of a deal and I was going to let them slide for a month or two because I don’t use ACC ever since i’ve bought the vehicle. The “front assist” part I guess I was using because it’s lit up a time or two over the 7 years life i’ve had the vehicle..... but not super super important to me. I care about these faults but i’m trying to prioritize and was initially putting these faults at a lower priority but do you think this will cause more problems? and if so, what kind of problems would you suspect?
FYI i super appreciate any of your feedback. I’m not taking it negatively... i’m listening!
'14 TDI Execline
I can't give you the answers that you want to hear.
The Touareg's systems are quite complex and there's a lot of collaboration that's required between different controllers and\or sub systems. This is why you get errors like this:
Think about it logically.... if you want your lane assist to function (as an example), but you have faults with the camera and the steering angle sensor, what inputs can the ECU use to determine that you're not driving between the lines or that you're not trying to correct the steering input?
If I were to blindfold you and spin you around before asking you to walk straight between some lines.... how would you know if you're between the lines or if you need to veer left or right to stay between the lines?
Discussion Starter · #18 ·
Okay I have a good question... does anyone know where a common point would be between the image processor cord and the steering wheel sensor? Like approx what location on the vehicle would these two cross paths? or a fuse?
1 - 20 of 23 Posts
