1 - 4 of 4 Posts
You need to run a VCDS scan to find out. Find a good VW independent to work on the car and tell you.
1) check your catalytic converter to see if it's clogged
2) check your O2 sensors. If the either sensor is weak, replace them both.
3) check your readiness codes with a VCDS. If any of the codes are no set, then you will not pass, but the test results should indicate if that's a problem.
1 - 4 of 4 Posts
