1 - 4 of 4 Posts
Anyone know how often you need to change antifreeze? I have a 2005 in Montana, I don't think the antifreeze has ever been changed. I bought it used in 2010 in Nevada.
Thanks for comments!
You can buy a cheap tester to DIY your coolant atrength and then make a decision.
Personally, after all those years, I'd get it changed anyway for peace of mind.
Do make sure you use the correct coolant for the Touareg if you don't get it done at a VW dealer.
Single cylinder 2 stroke air cooled engine?
Well I dusted off my old tester...antifreeze rated -22 Fahrenheit. The treg is in an attached garage, usually doesn't get below freezing. Coolant is pink, so I think I'm good. Thanks for the input.
Vdubbn
1 - 4 of 4 Posts
